ox locker where did you mount the lever?
No, the electrac is no more. I thought about it. A friend of mine had one last year - his sponsor gave it to him simply because it was old stock and he wanted a selectable for the rear. It failed shortly after, as apparently was typical of the design. The only saving grace of them was that they'd fail to be like a truetrac, so it actually didn't work TOO bad... His sponser coughed up a detroit softlocker (ie, a detroit locker) as the replacement.
Or, so I believe.
If it was me.. I would go with the ARB. 2 ppl in my local club were/are running the OX. Both of them had problems with the cable sliding, and not engaging the locker. Both of them converted the cable actuation to small air cylinders. :dunno: So if they would have started with an ARB... they never would have been denied on obstacles when their lockers failed. ( Chad's failed on Helicopter Pad (tellico) and he was in a pretty bad spot)
i ment the lines that go to the locker also theres not a whole lot of room for a compressor
Run it off a CO2 bottle. If installed correctly, they should hardly use ANY air. Ask your installer about running it off a bottle.
Also, when you get the ARB, spend the extra $50 or so and get the HD air line. It's a tough rubber line with a metal fitting at the end, so you don't have a rinky little blue line running down there.
