comanche13 Posted November 30, 2008 Share Posted November 30, 2008 ok so i found a hose and its cut in half but all i know is it goes to the vacuum canister anyone know what it is? its the little black hose going through the fire wall this is also in the line its the little one under the big one Link to comment Share on other sites More sharing options...
james750 Posted November 30, 2008 Share Posted November 30, 2008 Its probably to your heater controls. Go turn the truck on and see if the controls still work. If thats the problem, it should only blow out of the defrost vent no matter what position the heat is in except off (vent, bilevel, heat, defrost). Link to comment Share on other sites More sharing options...
aemsee Posted November 30, 2008 Share Posted November 30, 2008 :agree: Link to comment Share on other sites More sharing options...
comanche13 Posted November 30, 2008 Author Share Posted November 30, 2008 sweet thats exactly antidisestablishmentarianism i was hoping you guys would say Link to comment Share on other sites More sharing options...
djag12 Posted December 1, 2008 Share Posted December 1, 2008 Is the pink hose the same thing (for the heater) I have heat but only on passanger side and my pink hose is torn. Link to comment Share on other sites More sharing options...
aemsee Posted December 1, 2008 Share Posted December 1, 2008 pink goes to the water valve Link to comment Share on other sites More sharing options...
carnuck Posted December 1, 2008 Share Posted December 1, 2008 If there was another hose, I'd say cruise control reservoir (it's on the same bottle) I moved mine from behind the bumper (where it's easily mashed) to the inner fender. Went to a smaller vacuum ball too. Link to comment Share on other sites More sharing options...
djag12 Posted December 2, 2008 Share Posted December 2, 2008 Can you explain what the water valve is/does? Thanks Link to comment Share on other sites More sharing options...
aemsee Posted December 3, 2008 Share Posted December 3, 2008 Water valve is in the heater hose line. Based on heater control position it will allow or restrict flow of hot coolant in to the heater core. A lot of people just eliminate them when they start leaking. So yours may no longer be there. Link to comment Share on other sites More sharing options...
FxRacing282 Posted December 4, 2008 Share Posted December 4, 2008 although if you do have it i would keep it. i always thought ey were garbage and stupid until this summer i was cruising down the road windows open and whatnot but there was always a heatercore in my truck that was 160. (itll be like 210 for you) therefor my truck was always hot on the inside. its a luxury that i think if you got it keep it working. Link to comment Share on other sites More sharing options...
aemsee Posted December 4, 2008 Share Posted December 4, 2008 I agree with keeping it. I just bought one off e-bay for $10 plus shipping. Mine isn't leaking just yet, but it is pretty scary looking. :eek: Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 4, 2008 Share Posted December 4, 2008 although if you do have it i would keep it. i always thought ey were garbage and stupid until this summer i was cruising down the road windows open and whatnot but there was always a heatercore in my truck that was 160. (itll be like 210 for you) therefor my truck was always hot on the inside. its a luxury that i think if you got it keep it working. If your cab was hot after you eliminated and/or bypassed the water control valve then you have additional vacuum problems. Either the blend, panel, or floor doors are not closing or opening all the way as they should depending on the position of the climate control panel lever. There should be absolutely no difference in the cab temp with or w/o the water control valve connected when the C/C panel is set in either VENT or in A/C if the C/C system is working properly. Link to comment Share on other sites More sharing options...
FxRacing282 Posted December 5, 2008 Share Posted December 5, 2008 there is a 210 degree block in your cab less than 3 feet from you. heat transfers through plastic Link to comment Share on other sites More sharing options...
