Alternator Question
i need a new alternator and i called around a few places and each one had different amps, my question is does it matter cuz at napa they had a 160 amp unit and wanted to know if it would work in my 87 4.0 with ac
thanks in advance
The 160 amp unit should work electrically, AFIK a higher amp rating just allows you to pull more - compressor, winch, a/c etc. You only pull what the regulator allows, anything else is extra potential.
At the same price I'd go with the higher amp.
If you're concerned about mechanical fit have the guy put them both up on the counter. If the computer says it fits I usually trust 'em, but I only have a 10 min drive so you might want to be more careful.
