Rollbar Lights From Factory....Switch?
This popped into my head the other day...ive seen the bezel for the cargo light, but what does the rollbar light switch look like? Do they just use the same foglight bezel? Or do they use the space to the right of the trans switch and use a different icon?
There are four switch position, enough for everybody. To fill them on the XJ, it was fog, rear wiper, rear defroster, and power switch for automatic. On the MJ it would be fog, cargo, roll bar, and power switch. If you need more you have to lose the automatic.
Does the stock sport bar block the cargo light? Were these options mutually exclusive? I would guess the sport bar light switch would replace the cargo light switch if you have fog lights.
The rollbar does block the cargo light, makes it kind of a pain to replace the bulb.
Erik :beerhead:
