Project new life
  • Replies 57
Well aside from a cage and getting one more seat in it, IT'S DONE. Drives great, needs longer shocks in the front but that's no biggie. Hydro assist is beautiful, 2hi sucks but 4low is better than the previous setup with 4.56's and 33"s. Also got the rope on the winch but that was after the photos. I'll drive it to work tomorrow then it's onto the trailor for the remainder of it's life. Street drives great but after a trip from the house to the gas station, the tires were soft and sticky(moreso than I have ever seen) and that's alot of money to be laying on the hwy. In the pic, the driver rear is propped on 4' of pallets. Time to trim...
looks like time to bumpstop for you...your tires are WAAAY too big for that lift as it is.
bumpstop so it doesn't flex that far UP and gain some down-travel, and you're all set :brows:
looks good tho. had it out yet? a buddy of mine had beadlocks with lock rings similar to that...ended up cutting the center out wider because mud gets in there and stays (really bad vibrations)
  • 4 years later...
