No,yes,no.
Country of origin,build plant,make,model,body style,engine,year,
build sequence,emmission qualification...
that's all I can think of,might be more.
Both BLHTAZ and I work for dealerships,we can
usually decode a vin and tell you lots of stuff,as in
paint code,trim,options,etc.
At least for 1990 and newer vehicles.
Older than that,sometimes yes,sometimes no.
Can try yours if you either wanna post or pm it to
one of us. :cheers:
If you can't read this, PM me an e-mail address and I'll send you the diagram.....
Jeff
Image Not Found
Jeff
Image Not Found
It says 87+, is my 86 the same?
If so can you send me the digram?
I'm not sure, I only have the FSM for 87-90. I'd look at the ID plate on the door jamb for the letter codes to see if they match. Gimmie an e-mail addy and I'll fwd it to ya.
:cheers:
Jeff
:cheers:
Jeff
Or Ill just post on what I see.
Country :
USA
2
J
Manufacturer:
Jeep (USA)
3
7
Type:
TRUCK
4
F
GVWR (Gross Vehicle Weight Rating ) :
1819-2272 kg
5
T
Model:
Cherokee - 2WD
6
2
Series:
SE
7
6
Body type
Comanche, 2-door pick-up
8
E
Engine
2,5 litres, I-4, central injection
9
7
Control digit:
Has passed check
10
K
Year:
1989
11
L
Plant:
Toledo #1
12-17
402970
Serial number
402970
