jeep_freek88 Posted September 3, 2008 Posted September 3, 2008 I am going to take my valve cover off to paint it red, and replace the lines that are going to it. My question is do those bolts need to be replaced or can I just reuse them? :???:
Chico Posted September 3, 2008 Posted September 3, 2008 You can reuse them, but if you want get some new ones and do us a favor and post up the size in thread at the top of the tech section :cheers:
maddzz1 Posted September 3, 2008 Posted September 3, 2008 When I did mine I made sure to put them back in the same place they came from. You don't have to but I figured might as well.
robfg67 Posted September 3, 2008 Posted September 3, 2008 ...I degreased mine and added some light-duty Loctite to each bolt.
FxRacing282 Posted September 3, 2008 Posted September 3, 2008 make sure you paint the bolts too. if you don't it will look silly
jeep_freek88 Posted September 4, 2008 Author Posted September 4, 2008 I'm thinking Red cover and black bolts :brows: :cheers:
jeep_freek88 Posted September 4, 2008 Author Posted September 4, 2008 Also I am planning on using hightemp rtv gasket maker for my valve cover gasket; does any one have any thoughts that they would like to share on that???? :cheers:
maddzz1 Posted September 4, 2008 Posted September 4, 2008 Also I am planning on using hightemp rtv gasket maker for my valve cover gasket; does any one have any thoughts that they would like to share on that???? :cheers: Yeah, don't do it. Spend the $40 bucks for the felpro one; you won't regret it.
jeep_freek88 Posted September 4, 2008 Author Posted September 4, 2008 Also I am planning on using hightemp rtv gasket maker for my valve cover gasket; does any one have any thoughts that they would like to share on that???? :cheers: Yeah, don't do it. Spend the $40 bucks for the felpro one; you won't regret it. Bad experience????? I don't have the coin$$$$$$$ already have a tube of rtv any words of wisdom on using it?? :cheers:
jeep_freek88 Posted September 4, 2008 Author Posted September 4, 2008 Ok I thought back to when I was doing ball joints and had to just give in and not cheep out this time so here is what I ordered. Here It Is Your Right Maddzz
PIKE Posted September 4, 2008 Posted September 4, 2008 Yeah, don't do it. Spend the $40 bucks for the felpro one; you won't regret it. X2 The FELPRO gasket is a thing of beauty. If you ever tried to seal the valve cover with a cork gasket and rtv you know what I mean. :wrench: I used some black wrinkle paint on my cover turned out pretty nice. :cheers:
FxRacing282 Posted September 5, 2008 Posted September 5, 2008 I'm thinking Red cover and black bolts :brows: :cheers: DO IT
ORCA Posted September 5, 2008 Posted September 5, 2008 What kind of paint do you guys use for the cover? High heat rattle can?
jeep_freek88 Posted September 5, 2008 Author Posted September 5, 2008 Everything has to get expensive....................I mean everything All I wanted to do was replace the vacume hoses and paint my valve cover red for f*** sake why does everything have to brake the $100 mark well since I have already broke that amount with all three vacume hoses, valve cover gasket, thermostate + gasket, anti freeze, paint and serpintine belt :mad: I might as well get somthing els I wanted I want to get a new oil cap like a red billit alluminum one or whatever so please give me some ideas for that ....thanks :cheers:
maddzz1 Posted September 6, 2008 Posted September 6, 2008 Everything has to get expensive....................I mean everything All I wanted to do was replace the vacume hoses and paint my valve cover red for f*** sake why does everything have to brake the $100 mark well since I have already broke that amount with all three vacume hoses, valve cover gasket, thermostate + gasket, anti freeze, paint and serpintine belt :mad: I might as well get somthing els I wanted I want to get a new oil cap like a red billit alluminum one or whatever so please give me some ideas for that ....thanks :cheers: I know, everytime i go to do a job, the extra stuff or the tools end up costing more than the original part.
FxRacing282 Posted September 6, 2008 Posted September 6, 2008 Everything has to get expensive....................I mean everything All I wanted to do was replace the vacume hoses and paint my valve cover red for f*** sake why does everything have to brake the $100 mark well since I have already broke that amount with all three vacume hoses, valve cover gasket, thermostate + gasket, anti freeze, paint and serpintine belt :mad: I might as well get somthing els I wanted I want to get a new oil cap like a red billit alluminum one or whatever so please give me some ideas for that ....thanks :cheers: i hate that so much. alright this owuld be pretty cool. get a cap that has a thermometer on it. ive seen them at car wal marts (autozone, advance some napa's, ect.) they arent too bad looking plus you could be like yeah well the oil in my truck runs about 240 degrees or whatever
jeep_freek88 Posted September 6, 2008 Author Posted September 6, 2008 Everything has to get expensive....................I mean everything All I wanted to do was replace the vacume hoses and paint my valve cover red for f*** sake why does everything have to brake the $100 mark well since I have already broke that amount with all three vacume hoses, valve cover gasket, thermostate + gasket, anti freeze, paint and serpintine belt :mad: I might as well get somthing els I wanted I want to get a new oil cap like a red billit alluminum one or whatever so please give me some ideas for that ....thanks :cheers: i hate that so much. alright this owuld be pretty cool. get a cap that has a thermometer on it. ive seen them at car wal marts (autozone, advance some napa's, ect.) they arent too bad looking plus you could be like yeah well the oil in my truck runs about 240 degrees or whatever Hmm, Sounds cool Ill have to have a look. I just don't want to get the stock yellow boring one.
DirtyComanche Posted September 6, 2008 Posted September 6, 2008 I don't know if you can run one of those fancy ones...? Anyways, the stock replacement one is like $10, and it's not yellow anymore. Kinda a grey/black. Well, it cost me $10. So I imagine it's like 2.99 in the states.
jeep_freek88 Posted September 6, 2008 Author Posted September 6, 2008 I don't know if you can run one of those fancy ones...? Anyways, the stock replacement one is like $10, and it's not yellow anymore. Kinda a grey/black. Well, it cost me $10. So I imagine it's like 2.99 in the states. oem Is yellow still and yea 5.99 for oem replacement the black one is 2.99 murry brand.....I think Ill just go with the black one It will match my bolts and look pretty sharp I think :brows: :cheers:
jeep_freek88 Posted September 6, 2008 Author Posted September 6, 2008 Ok just got back from the parts store with the cap $2.99 High gloss black with good rubber seal........sweeeeeeeeet Its going to work great and look good too Ill post before and after pics. Its all going to be done on tuesday........ :chillin:
