whalebus Posted July 25, 2008 Posted July 25, 2008 I almost got out of the sport of 4wheeling ,mostley because I suck as a driver and 2cd my pathfinder never did drive the way I wanted it to but then I saw this beauty in my freinds junk yard and decided to turn to the dark side and get a jeep.Its a 89 comanche 2 wd no ac and it needed a fuel pump.I sold my pathfinder minus axles so those are going to go under here.IT will have a 44 front locked chromo, and a nissan rearlocked ,disk brakes 4:56 gears and an anti rock swaybar with 36 tsl on beadlocks.got it home and got it running and swapped out to a 4 wheel drive tranny and transfer case.then I tapped my steering box for hydro assist then torched all unneccesary brackets off and slapped the front axle under there on leaf springs.I never liked the leafs on my pathfinder so I decided that I woulnt like them on this either so I decide to radius arm the front and 4 link the rear.Bach is pretty much doing the build for me so he will keep me updated with pics so stay tuned.same bat station same bat time.
MiNi Beast Posted July 25, 2008 Posted July 25, 2008 Welcome back to 4 wheeling at least this time you got a better start, a jeep you know :D
whalebus Posted July 25, 2008 Author Posted July 25, 2008 yea,its nice having a great after market because nissan had none
whalebus Posted August 28, 2008 Author Posted August 28, 2008 well its been awhile but I am just about threw.I need to build a new crossmemeber and a couple of litle things and I should be ready to wheel
reson46 Posted August 28, 2008 Posted August 28, 2008 well its been awhile but I am just about threw.I need to build a new crossmemeber and a couple of litle things and I should be ready to wheel I'd be interested in seeing some more pictures of your rear suspension. :D Willy
Casper2000 Posted August 28, 2008 Posted August 28, 2008 Nice setup on the rearend. I want to do that to my Manche. Looks good :bowdown:
whalebus Posted August 28, 2008 Author Posted August 28, 2008 thanks,I can't take all the credit becauase my buddy did all of the fabbing and I just supplied the labor.I will get more pics up soon when we finish the crossmember this weekend
89eliminator Posted August 28, 2008 Posted August 28, 2008 i have a question, if you didnt like leafs and wanted the radius arm the front, then why did you even put the leafs in?
ORCA Posted August 28, 2008 Posted August 28, 2008 i have a question, if you didnt like leafs and wanted the radius arm the front, then why did you even put the leafs in? I was thinking the same thing, but i'm assuming he bought it from the JY with leafs in the front. Which means this jeep has had a history of pretty heavy modifications. Either way, bitchin' jeep! Great start and welcome to the dark side of wheelin' :cheers:
whalebus Posted September 1, 2008 Author Posted September 1, 2008 I put leafs under it because i allready had them and decided against it once it was under there so I started over
twojeeps Posted September 1, 2008 Posted September 1, 2008 is that a rattle can paint job?? just curious b/c thinking of doing mine in that color
whalebus Posted September 1, 2008 Author Posted September 1, 2008 I couldnt tell ya.It was that way when I bought it but it has been repainted.
whalebus Posted September 9, 2008 Author Posted September 9, 2008 My bed is trashed and I was wondering if any one had any cool ideas for a flat bed or pics?
Pete M Posted September 9, 2008 Posted September 9, 2008 You might want to ask that question in the tech forum. You'll get more responses I'm sure. :cheers:
