Pete M Posted July 18, 2008 Share Posted July 18, 2008 For those of you that needed to replace the 14mm leaf spring bolts, where did you get them? Online source? Or what did you go with if you couldn't get an exact match? The best my local hardware store has in 14mm is an "8.8" strength (comparable to grade 5) and I was hoping to find some in "10.9" (or better if I can, since I somehow managed to bend one of the 10.9s I had previously). Link to comment Share on other sites More sharing options...
brigarpeon Posted July 18, 2008 Share Posted July 18, 2008 http://www.fastenal.com/web/products.ex ... 9323&Nty=0 http://www.mcmaster.com/ Metric Bolts > Metric Thread Size Head Style Standard Hex System of Measurement Metric Metric Thread Size M14 Thread Direction Right Handed Grade/Class Class 10.9 DIN 931 Steel Zinc-Plated Class 10.9 2 mm 80 mm Partially Threaded Deutsche Industrie Normen (DIN) 95327A739 3.24 per Pack of 1 DIN 931 Steel Zinc-Plated Class 10.9 2 mm 90 mm Partially Threaded Deutsche Industrie Normen (DIN) 95327A742 3.50 per Pack of 1 DIN 931 Steel Zinc-Plated Class 10.9 2 mm 100 mm Partially Threaded Deutsche Industrie Normen (DIN) 95327A745 3.54 per Pack of 1 DIN 931 Steel Black Class 10.9 2 mm 50 mm Partially Threaded Deutsche Industrie Normen (DIN) 91310A786 8.20 per Pack of 5 DIN 931 Steel Black Class 10.9 2 mm 60 mm Partially Threaded Deutsche Industrie Normen (DIN) 91310A788 7.05 per Pack of 5 DIN 931 Steel Black Class 10.9 2 mm 70 mm Partially Threaded Deutsche Industrie Normen (DIN) 91310A790 9.17 per Pack of 5 DIN 931 Steel Black Class 10.9 2 mm 80 mm Partially Threaded Deutsche Industrie Normen (DIN) 91310A792 9.81 per Pack of 5 DIN 931 Steel Black Class 10.9 2 mm 90 mm Partially Threaded Deutsche Industrie Normen (DIN) 91310A794 8.31 per Pack of 5 DIN 931 Steel Black Class 10.9 2 mm 100 mm Partially Threaded Deutsche Industrie Normen (DIN) 91310A796 12.14 per Pack of 5 Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 18, 2008 Share Posted July 18, 2008 Chrysler Parts Direct has them, p/n 34202118, $4.66/ea. Link to comment Share on other sites More sharing options...
mjeff87 Posted July 18, 2008 Share Posted July 18, 2008 Pete, how bad off are yours? When I redid my leafpacks, I considered replacing all the mounting hardware, but I broke out the bench grinder with the wire wheel.......what I thought was bad was really only surface rust. I cleaned my originals up and reused them. The factory stuff is case-hardened, which is kinda difficult to find unless you go dealer like Don said (at least down here it is). Jeff Image Not Found Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 18, 2008 Share Posted July 18, 2008 BTW, the 91+ XJ LCA bolts are the same part number as the leaf spring bolts. :eek: Link to comment Share on other sites More sharing options...
Pete M Posted July 18, 2008 Author Share Posted July 18, 2008 Pete, how bad off are yours? When I redid my leafpacks, I considered replacing all the mounting hardware, but I broke out the bench grinder with the wire wheel.......what I thought was bad was really only surface rust. I cleaned my originals up and reused them. The factory stuff is case-hardened, which is kinda difficult to find unless you go dealer like Don said (at least down here it is). Jeff One is bent, one was cut, and another other has permanently bonded itself to the bushing sleeve. I would use the ones that came with the rust-free florida packs I'm installing, but I think I scavenged them for use in the '90 after I had to cut several of its bolts to get the leaf packs off. Rust sucks. :mad: I'm going to use half a bottle of anti-seize on the next ones. :rant: Link to comment Share on other sites More sharing options...
mjeff87 Posted July 19, 2008 Share Posted July 19, 2008 ahhh......ya.... :eek: Fastenal, or the dealership then (and I thought PA rust was bad......) Jeff Link to comment Share on other sites More sharing options...
Pete M Posted July 19, 2008 Author Share Posted July 19, 2008 I was hoping for something stronger than 10.9, but I guess I'll be making due. Thanks guys! :cheers: Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 19, 2008 Share Posted July 19, 2008 Find a good machine shop and they can get you the 12.9 stuff, and quite possibly even stock it... So, how did you get that bolt out that has the sleeve seized on it? Link to comment Share on other sites More sharing options...
500 MJ Posted July 19, 2008 Share Posted July 19, 2008 Find a good machine shop and they can get you the 12.9 stuff, and quite possibly even stock it... So, how did you get that bolt out that has the sleeve seized on it? You don't want to know... Pete, aren't these bolts the same ones used in the LCA's for the front end? If so, I would go to the yard and get some from there. I've never had one stick on the front end of an XJ/MJ... :dunno: Link to comment Share on other sites More sharing options...
Pete M Posted July 19, 2008 Author Share Posted July 19, 2008 This project is taking a break until I return from my trip to Georgia (22-29th) so I'll have time to contemplate my next move. I'm very frustrated with it and a breather will be good for me. As to the sleeved bolt, check out the project's page and you'll see. :( http://comancheclub.com/forums/viewtopi ... 5&start=15 Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 19, 2008 Share Posted July 19, 2008 Pete, aren't these bolts the same ones used in the LCA's for the front end? If so, I would go to the yard and get some from there. I've never had one stick on the front end of an XJ/MJ... :dunno: BTW, the 91+ XJ LCA bolts are the same part number as the leaf spring bolts. :eek: Read much? :cheers: Link to comment Share on other sites More sharing options...
