Everything posted by smithe1811
I'm going to need to replace my front springs soon and i am in need of some advice from the Manche Masters. I have a 4 inch lift and am looking for some decent springs at a low price and i basically want to avoid buying somewhere cheap and end up breaking one. just something mostly for DD use with mild wheeling and very little highway. Thanks Erik
:hijack: So my 88 4.0 with a ba-10/5 will most likely have 3.08's?
Whasnt there a post someone made on where you could buy it new? quite some time ago if i recall correctly.
Shock Recomendations...
smithe1811 replied to ocskipper's topic in MJ Tech: Modification and Repairs
Thanks, I am going to try a pair. Let me know how they work out, i need some new ones as well. -
:fs1: Due date of baby number 2! :banana: its bitter sweet i guess..
What about these ones? http://roughcountry.com/shocks_rc9000.html -
My 86 only had 31x10.5x15 on it the whole time i owned it, i never had any problem either sans the LCA rubbage.
Couple O Suspension Questions
smithe1811 replied to smithe1811's topic in MJ Tech: Modification and Repairs
I know better than to jack it by the axle to check the problem, lifting it by the frame is when it happens, soon as i get a few mins i will try unbolting them to see what happens, I'm about 99% sure that thats the problem.Ill report back to yall -
Basically, if i go out and put a jack under the whole front end of my truck and lift it up, it will come right off the groung rather than the suspension decompressing and then coming off the ground. -
how would i do that? if were to use if for an oil cooler?
it seems to me like the shock is reaching full extension, like maybe whomever lifted the truck did not upgrade the shocks. -
Can you tell its nice out? i have a thousand questions because ive been out doin stuff to the MJ all day. Anyway, I finally decided i wanted to get rid of my drop brackets so my first question is what parts will i need to procure after i remove those to keep my 4" lift. my second question is probably a stupid one but here goes, shouldnt there be some upward movement in my suspension? the way my truck sits now, the suspension is maxed out, all the way up. Thanks Erik
Does anyone have a good pic or write up on how the factory electric fan is installed? I'm looking in the FSM and the elec manual and its not really helping me here. i know alot of guys are puting their fan on a seperate switch but i just want to hook it up the factory way for now so any help here would be GREAT!
Thank you once again i just wanted the electric fan from it.
Disconnected hose, what is it for?
:dunce: cool thanks! :thumbsup: -
Found this hose just hanging there, could this be why my parking brake does litterally nothing to stop/slow my truck from rolling backwards?its the one on the top left and it goes down to the top of the axle, the hose on the right. oh and where does it connect to? Image Not Found
Well, when i started tearing into my parts pig i found these two hoses and I'm not sure what they are for, they go from the radiator to the tranny(aw4), are they part of the heavy duty cooling system? the truck had both cooling fans in it. also if they are a useful part, will they work on a ba-10/5? its the two smaller ones at the top and bottom of the rad Image Not Found here they are running from the right Image Not Found pic from the front of the two running to the back, they go right ointo the side of the tranny pic of my DD setup Image Not Found
well, i figured out where the number 2 bracket goes, i reversed them :dunce: and all the holes lines right up, i thought they were supposed to point out toward the front of the truck because the drivers side bracket lined up perfectly with some 13mm bolt but nothing on the passanger side, but when i flipped them they lined up with 2 holes on the frame, the number one brackets i don't even have i just needed to know if there were important or if there were to adapt some other option i don't have and the other part in the back, there isnt a hole that goes all the way through thats why i asked if there was supposed to be a captive nut. I do like those hi country ones, one day ill get the ones with the d ring mounts, but until then.... Thanks Erik
sooo nobody has factory ones anymore? i don't have the dough to buy some aftermarket ones right now and i have some stuff that needs to be uprooted so i want to make sure my hooks are on there as best they can be.
So does anyone actually have a pic of their factory hooks installed? i have a couple of questions, number one is the brackets on the bottom(number 2 in the pic) where do they attach? also the part labled 3, is ther supposed to be a captive nut from the factory in the frame to fasten it to? and what are the brackets lable 1 for? Image Not Found thanks Erik
That almost sounds like Dennis Leary....
i have three of them now and all three have different strong points http://agm65.mybrute.com http://aim9.mybrute.com http://igottamohawk.mybrute.com yet another game to pass my down time i guess.......
The Man Rules At last a guy has taken the time to write this all down Finally , the guys' side of the story. ( I must admit, it's pretty good.) We always hear "the rules " From the female side. Now here are the rules from the male side. These are our rules! Please note.. these are all numbered "1 " ON PURPOSE! 1. Men are NOT mind readers. ( FIRST & FOREMOST RULE) 1. Learn to work the toilet seat. You're a big girl. If it's up, put it down. We need it up, you need it down. You don't hear us complaining about you leaving it down. 1. Sunday sports, It's like the full moon or the changing of the tides. Let it be. 1. Crying is blackmail. 1. Ask for what you want. Let us be clear on this one: Subtle hints do not work! Strong hints do not work! Obvious hints do not work! Just say it! 1. Yes and No are perfectly acceptable answers to almost every question. 1. Come to us with a problem only if you want help solving it. That's what we do. Sympathy is what your girlfriends are for. 1. Anything we said 6 months ago is inadmissible in an argument. In fact, all comments become Null and void after 7 Days. 1. If you think you're fat, you probably are. Don't ask us. 1. If something we said can be interpreted two ways and one of the ways makes you sad or angry, we meant the other one 1. You can either ask us to do something Or tell us how you want it done. Not both. If you already know best how to do it , just do it yourself. 1. Whenever possible, Please say whatever you have to say during commercials.. 1. Christopher Columbus did NOT need directions and neither do we. 1. ALL men see in only 16 colors, like Windows default settings. Peach, for example, is a fruit, not A color. Pumpkin is also a fruit. We have no idea what mauve is. 1. If it itches, it will be scratched. We do that. 1. If we ask what is wrong and you say "nothing," We will act like nothing's wrong. We know you are lying, but it is just not worth the hassle. 1. If you ask a question you don't want an answer to, Expect an answer you don't want to hear. 1. When we have to go somewhere, absolutely anything you wear is fine... Really . 1. Don't ask us what we're thinking about unless you are prepared to discuss such topics as Football or Hockey. 1. You have enough clothes. 1. You have too many shoes. 1. I am in shape. Round IS a shape! 1. Thank you for reading this. Yes, I know, I have to sleep on the couch tonight; But did you know men really don't mind that? It's like camping.
dang, if you werent 3 hours away ide come over there this weekend and buy some.....then probably shoot them all before i came home ;) BTW, anyone read up on this one? http://www.rightpundits.com/?p=3732 here is the report http://www.fas.org/irp/eprint/rightwing.pdf
Is that why i got 15 pupils last night?
