Everything posted by dakal
adding to thread: THINGS TO DO 1.rebuild 231 with neutral switch & short shaft kit 2.fix exhaust leak 3.install brake booster, need new lines for master cylinder, line stop, & adjustable porportioning valve. Remove back porportioning valve 4.replace clutch reservior 5.replace stock transmission mount with urethane mount, [adapt mine and or replace] 6.check control arm for type of bushing, and or replace. Add bracing to arms 7.have driveshaft shop lengthen front driveshaft 8.make steering box brace 9.replace radiator with 92 or newer radiator & catch can 10.replace doors if possible 11.buy 32 gal gas tank and install with fuel pump and lines where needed 12.remove charcol canister & lines & plug done 13.build spare tire mount 14.weld spot welds with stitch welds on frame & suspension 15.replace springs 16.mount new shocks 17.make brackets for front shock mounts 18.make fender stiffener from shock mount to shock mount across motor 19.six wheels and tires done 20.brakes done 21.axles r&r done 22.mount gauges & pod including wiring them 23.mount inverter & wire it 24.move battery done 25.mount passenger seat 26.mount corbeau seat belts 27.make bar for seat belts 28.make bar for passenger feet 29.make bar for passenger hands 30.finish interior 31.mount new hood 32.mount air cleaner with hose for outside air 33.mount spot lights with relay and wiring 34.make brace to stiffen bed sides above spare tires 35.make or buy then mount tool box 36.move rear bumper closer to frame 37.make mount for hi-lift jack 38.mount spare tie rod 39.fix speedo 40.mount accusump,lines, whatever foa is $ 165.00 41.make front bumper out of one inch tubing 42.fix back slider window- drill holes to mount some kind of latch 43.mount amber light 44.pull transmission & check rear main seal,flywheel, pressure plate, throwout bearing, pilot bearing 45.put spares in tool box 46.map senser 47.coil 48.resister 49.belt 50. make skid plates for gas tank, transmission, engine, and front of engine out of alum 51. install wink mirror done 52. replace windshield done the list to finish before baja or reno,las vegas
yes i am :bowdown: its about 130 miles from me
go through there on my way to surf
new photo sorting out the rig for offroading. with new springs the set will be different, most of the inprovements will be internal. :banana: [/img]
i have rusties on my mj. they are$90.00 per side :D [/img]
i said it backwards. i change the filter every time and the oil every other time. if i prerun i change the oil afterwards.
the reason i changed the battery and cables is they were all bad, plus, my truck weighs 2200 lbs in front and 1400 lbs in back. next to the battery i'm installing a 32 gal fuel cell, next to that a lock box for whatever. on the battery side of the truck bed, i'm making a quick release holder for my two spare tires. also a brace for the middle of the bed. plus at least two 5 gal gas cans for the motorcycle guys. camping gear. that will bring the rear weight to 2000 to 2100 lbs. approx. maybe even 2200 lbs. i haven't calculated the exact weight yet. i don't like the battery hanging out on the front of the rig. i once found battery acid all over that part of the fender. the goal is as much weight as possible, inboard of the axles. :D
i removed the curved part of the seat bracket and made two brackets to level the seat, and to be able to bolt it in.[/img]
i use mobil 1, change it every 3000 miles, :popcorn: use a good filter and change it every other oil change.
don't know why pics went sideways. i used # 2 welding cable ang strung it through 3/4 " garden hose where it went along the frame. i changed things up front to get it away from the motor.
i have now changed the battery location. took longer to finish then expected. [/img][/img][/img][/img]
just had a new windshield installed. i paid $75.00 & insurance paid $267.00 8)
what a bunch of cool posts. your all right- raising your kid or kids is the most important thing you will do. :D
i'm running bilsteins 5150's. on my bmw i use bilstein sport shocks. they are a great company and build great shocks.
for tie rod ends, take water pump pliers and squeeze the tie rod top to bottom, any play baaad it is :popcorn:
according to the guy who r&r my axles, he said most of the scout guys left the inner one out. so thats what i did.
i ran 3.55 's with 33 's . 5th gear was for going down hill only. 3.07 's sounds horrible. ba-5 trans :eek:
Cold air intake/ duel exhaust
dakal replied to led_balloon's topic in MJ Tech: Modification and Repairs
what size motors -
that makes sense after looking at it. tomorrow i will see if it will snap together. stay tuned :USAflag:
thanks, i took the cluster loose, not sure whats missing. i'll take your suggestion and look at the cable to see where is the best place on mine to secure it. :cheers:
i have a 88mj with a transplanted ax15. can i just replace the clip at speedometer or does the whole thing need to be.
