91mj97tj
91mj97tj's Achievements
Can Spell Comanche (2/11)
http://en.wikipedia.org/wiki/Visocica
Thompson or Ron Paul
Yeah it is open or locked just like an ARB or OX. The problem with OX is the cable is really testy you have to mount it just right and finding a place to mount it is pretty hard. Easier in an MJ but not so easy in a crammed TJ. ARB you just have to do all the air lines and junk. Which everyone loves them they are tried and true. But I really don't want to put one in my Wrangler. Even with the benefits of having a compressor. Plus who needs one when everyone has them and you can get your tires filled up by someone on the trail. As far as the Eaton is concerned a lot of the first ones have had problems but I have heard they are getting better and so I am interested in just a flip of a switch.
but I am not fond of the 80's year Jeeps they have a lot of little issues and problem with them. If you are going to do a full resto-sort of mod just get the cleanest body. But I think that is a pretty fair trade. If not for price. Well it will take you how many hours and how much is your time worth?? That is the trade off for him. Is this guy gonna help you do it? It takes a while to do the whole drivetrain swap. I think that is the most time consuming part. Also the whole hookup for transfer case was pretty tough for me. If I did it again I would have got the one that just mounts and comes off the TCASE instead of trying to do it like stock. The axle doesn't take long at all. But that is a pretty time consuming knuckly bashing work.
Yeah I would just use the shafts and get rid of that crappy disconnect. Don't downgrade to low pinion. But it is direct bolt on.
Have you seen where the 97 A/C system is on a TJ? It is like way in the way. Plus for several other bolt on things that I was thinking like many supercharger options it is in the way. Plus it just sucks many people damage the line that runs above the radiator to the a/c. Mine is damage granted I bought this TJ used but it has a bunch of rubbing going on in the aluminum lines. I figure moving it out of the way is the best way and the 2001 TJ has it I think either above the steering pump or below probably above it but you can even see it. Or as you can see this is what I have http://www.stu-offroad.com/engine/belt/belt-1.htm This is what I want: http://www.stu-offroad.com/engine/belt/belt-2.htm Granted 98 TJ and mine are the same 4.0 with a/c and the 2004 is the same range I am looking for.
Well I am just curious this is an unrelated mj question more of a TJ question so if anyone has a TJ and has done this I would appreciate anything you may have heard. But anyways 97 and I think to 99 or 00 TJ's have the A/C system routed in a really stupid way at least I think so it is above the alternator. But in the 2001 and later they have it mounted down below the steering pump Is there any way that you can just get an 01 a/c system and just relocate it? I haven't found anything that could help me online so anyones guesses would be appreciated.
They are lower than that in Utah. I work for Mountain America Credit Union. You can have usually 2-3 inquires on your credit a year to not affect it also. Depends on what they use. Most mortgage companies require all three bureaus, Experian rep told me 2-3 inquiries will not drop your score. But I would look into a Credit Union for a better rate. We are really good, but are closest location is in Alburque. What kind of mortgage is this a purchase or refi? Interest rates were dropping on homes at least in this market, but they are afraid of inflation within the next year in America so the federal reserve may look to raise them again (SCARY!!) By lower I mean by like a quarter or so. But that is pretty good so you must have good credit. We have promotions like at our credit union on how much you have invested in the Credit union and you can get like discounts of a quarter to a half.
Well my pal has a 2.5 Liter Cherokee. It is a 91 the same year as mine and they sit kind of low and are just like the ones put in MJ's
For the seats you have to find a 2.5 Liter XJ they are like direct bolt on and they don't sit you as high if you did a little modifying like moving the brackets from the bench onto the donor XJ seats. Which I did and I kind of miss the bench but at least people will stop trying to cram in the front seat with ya and get some ace on ace action I hated that in high school. For the A/C it could be a lot of things I would get a voltmeter and see what is going on in there.
Yeah we really have to be adults and I think they should impose heavier fines and even like community service in that area. It makes you so upset that people do this. I probably learned my lesson when I was a kid when there was these guys camping down the ridge from us. They were spotlighting, shooting does and just causing ruccus. I remember seeing a dead doe that they shot that they just left out there. I realized then that if we don't be responsible than these morons will just destroy everything in their path. Needless to say they got all the their trucks impounded, atv's guns etc. They got like 20,000 dollars worth of fines because they poached so badly in this area. It really affected the wildlife in that area. It really saddens me to this day. Tread lightly and remember leave an area cleaner than you left it. Don't ever poach as well. But they may need to close the areas so that the habitat can recover and I believe in that. Maybe in a few years they will open it up. Too bad that the government has to make decisions for us.
