thanks for the replies
old pic, i do have a steering stabilizer. ome i think.
no problem with steering lock to lock.
the axle bracket is on three sides and is pretty thick, but i'll look at bracing. the bracket is as far over as you can put it , so i don't know how to make the track bar longer. maybe with the placement of the coilover and bump can i can gain some length. ideas.?i like where the steering goes to, so i don't want to change that part. i have a 4" drop pitman arm. i could put the stock one back on, would that help the cycling.
caster is within stock settings. i had death wobble until we tightened the track bar at the frame. went away.
axle is perfectly centered. ford dana 44.
what belly?????? i have a two pack
? how can i make the track bar and drag link the same length with my set up? so far its drives great through bumps, but i'm putting a coilover in front. i am worried about this set up, thats why the questions.
and the bfg's AT's work great in the dezert.
the sway bar brackets clear everything. bad pic.
also, i could put track bar in lower hole, and with stock pitman arm would this be better?
