Frankdm83
Everything posted by Frankdm83
Go with SEM trim black, it matches most OEM black trim
Make sure you hit up a Primanti Brothers for a "Pittsburgh" cheese staek.
Does anyone have a pic or diagram how the door rods go in the door? I bought mine without the door panels since I was swapping to manual from power, but cannot remember how the roads run. Thanks is advance
LETS GO PENS!!!! scratch my back with a hacksaw
That is exactly what I needed to see, thanks!!!
Does anyone have a good pic of how the spring goes on. I was changing the front cable and it came off before I coulsd see where it went. It is the spring that holds the tension on the pedal so when you release it, it springs up
Bloomsburg is nowhere near 79. It is on the eastern side of PA. Your best bet would be Cranberry, jsut north of Pittsburgh on 79, or Sharon PA, which is a little farther north on 79. Sharon is the original location. I would suggest a Pittsburgh cheesesteak from Primanti Brothers in Cranberry.
I took the factory speakers out of my 89 when I changed doors and am jsut getting around to putting new speakers back in. The only plug i can find in the driver's side that looks like it could be right has 3 wires to it. Can this be right? 2 of the colors match the output wires at the stereo harness.
Take a trip to Walter's in East Freedom. pull your own parts and reasonable prices. Let me look in my shed I may have some lying around.
It will fit, but will not lie flat due to the wheel wheels
If you look at the picture of the rotor, it looks like there is a flat spot on it where it may have been dragging the road wich may suggest the wheel broke first
I myself have used 2 of their lift kist on my XJ and MJ with no problems. I break the tie rod on the track bar and they replaced it quickly. I have had known of friends to use their kits on 3 different vehicle with no problems either.
I don't have a pic of mine right now, but I bought a front hitch/tow hook set up from Rusty's. It is very stout for doing the same thing, and looks good too.
How to remove 97+ XJ parts quickly?
Frankdm83 replied to 87Warrior's topic in MJ Tech: Modification and Repairs
Make sure when you get the antenna you get the wire from the radio too. It is 2 pieces and you will need both. Ask me how I know this? I still need the inner wire. The clips on the door latchs will probably fall down into the pillar, take off the trim to get them. I would take the washer bottle also, and if time permits, get the brake m/c and booster -
About $30
Well it let me down again, starting to think the ignition swith in the column may be bad or need adjusted. Anyone have specs on how to adjust it?
Well it is now alive once again. Turned the key on and jumped the starter solenoid and she fired up. Drove it to the shop to finish hanging the exhaust back up, pulled it in shut it down and it refired 3 times. Must have been froze up from the cold weather?
I will try that first, a lot easier to get to as well and less expensive to change. I did not hear any sounds at all. Hopefully that is it.
Jsut finished putting the MJ back together after painting it and now it will not start. Made sure the ground for the taillights/fuelpump is grounded well. Checked the battery, it was toast, got a new one. Put new battery in and still will not start nor turn over. NO clicks or anything. I tried pulling the lights on, and they stay one when the key is turned, the after market radio however turns off when the key is turned to start. I am going to pull the starter today and have it tested today, if it does not snow too much before I get to it. Any ideas if the starter is good? :headpop:
Only good thing in Cleveland is A Christmas Story house, and in the movie I don't think they made it out to be there
I changed my arms to a newer Cherokee arm and use the Bosch Icon blades in 18. Awesome blades!
I already have to non disco axle, I just figured on doing the shafts before I put it in
I am upgrading my front axle to a non disconnect. I want to upgrade to bigger shafts as well. I know the XJ ones with ABS will work, but will Grand Cherokee ones have the bigger u joint as well?
