Frankdm83
Everything posted by Frankdm83
  1. I am pretty sure there was no trailer harness. I will have to look into when the wind dies down some. I was hoping it was something simple, but 3 or of 4 corners workign won't cut it.
  2. Woudl it only affect one side?
  3. I need to get my MJ through PA state inspection next week. The only issue I have is that the taillights light, but the passenger side pone does not brighten when the brake is pressed. The driver side does. It will not work with the 4 ways either. I tried the easy fix, new bulbs, but got the same result. Anyone else ever have this issue?
  4. Mine was leaking from the sending unit. One of the metal lines worked its way loose.
  5. What is broke on it? maybe I can Frankenstein 2 into 1 good one.
  6. Bump, still looking
  7. What shape is the sending unit in? I am in desperate need of one to get my MJ back on the road.
  8. Need a fuel pump sender for my 89 Pioneer 4.0 SWB. One of the metal lines is loose from the sender.
  9. I knew it could not be that easy!
  10. I know the ZJ rear disck brakes will bolt onto the 35 in the back of the MJ's, but will the Wj ones bolt on as well? I can get a great deal on them if so, basically swap them and hand over drum brakes off my MJ for scrap.
  11. I was trying to avoid a trip to the salvage yard in the heat and bee season
  12. D35
  13. I need a drum brake bar for my 89, passenger side. I know I should upgrade to the 8.8, but not financially possible right now. shipped to 16602
  14. PA is a big state. Where exactly?
  15. I will check that in the morning, thanks Pete
  16. I get a text today from a buddy that I have brake light out. I figure no problem, push the pedal down see which one is out and change it. So I put a brick on the pedal, walk out to the back of the truck and both brake ligths are out on the passenger side, so easy fix, right? WRONG! I took both bulbs out, put the new ones in. Checked taillights, good to go. Put the brick back on the brake pedal, still no passenger side brake lights. Any ideas? I checked the socket wiring and it looks good.
  17. My friend does this stuff on the side. He is a graphic designer. Either a pic or tracings and he can make it. Email him at dpapilonious@yahoo.com
  18. I will take a black one and brackets!
  19. You mean Ryan Miller, lol. Sid owns him. Game winning shootout goal in the first Winter Classic, hat trick earlier this year, and the winner today. Guess who Sid and the Pens play Tuesday?
  20. I am currently working with a friend of mine to possibly start making some MJ decals. I traced my pioneer stripes before painting it. I have to get them from the guy who painted it and should be in business. I will let you guys know. He can make about any custom decals you would like. I will see if I can pass out his email.
  21. 3.08 gears, no posi, looks like its out of a car
  22. They make a tool for it that goes on a drill, and is like a big eraser. It takes the decals and all the adhesive under them without scratching the paint. I got mine from a body supply store.
  23. Only got about 7 or 8 here in Central PA, pretty normal for us.
