11
The worlds Fastest Comanche
DirtyComanche replied to Worlds Fastest Comanche's topic in Member Projects: Your Comanches
You'd be suprised how much power can be pulled from a motor that has a high volumetric efficentcy and a high redline... There's a lot of N/A drag cars out there that will do some seriously mean times. And a lot of the guys who are into the bonneville (sp?) thing will run N/A nailheads and other such engines that are really NOT known for being efficent, nor do they have huge displacement. But like I said, I think the weight cutting will be very important. You're starting at around 2900lbs (S/B) or 3100 (L/B), and you're going to want to decrease that number by a lot! -
Engine from the same family, so a head from the same family is fine? Because the 4.2 and 4.0HO heads do not have the intake ports in the same location as a renix 4.0L. At least, not on the manifold side of things... The better (HO) heads have the intake port raised. It's worth power, quite a bit of it. I think you should think about weight reduction. Because I like that topic. How much can you mod the body/frame? -
brake rotor rubbing on knuckle
DirtyComanche replied to BPB's topic in MJ Tech: Modification and Repairs
There's differences between 2x4 and 4x4 models, plus differences based on the year. So yeah... -
my daily driver manche
DirtyComanche replied to offroadman83's topic in Member Projects: Your Comanches
That's a clean looking machine. Glad to see you decided to eschew the wood-grain. -
rear fender trimming?
DirtyComanche replied to redneck23ms's topic in MJ Tech: Modification and Repairs
Clean up the pinch seam, and look closely at it. You can see the spot welds, they'll be circular dimples/bumps. Cut past those and she'll pop apart. -
It's the special prize when you reach 5000 posts. Only 1581 more and you guys don't have to put up with me!
Project 2drx4. A cherokee.
DirtyComanche replied to DirtyComanche's topic in Member Projects: Your Comanches
Man, it looks like such white trash with all that junk in the back... I should learn to clean things up and 'poise' the jeep for pictures in the build thread. -
I know ECU's "nearly" never go bad, BUT...
DirtyComanche replied to BLHTAZ's topic in MJ Tech: Modification and Repairs
That intake gasket is a weak point, so do as Cabz suggested and check it... Or perhaps even consider just replacing it, kinda an ugly job but you can look at other things when you have it all apart. -
I guess I'm going for it... I figured I needed to take everything apart. Maybe because I'm sick in the head and just enjoy that. Ohwell. So, I removed the windshield using one of the not recommended methods (it involved a crowbar, don't worry it was cracked all over anyways). And stripped out the remaining interior and the engine bay. The engine is mostly ready to pull, other than the two fuel lines. Image Not Found The procedure I used for tcase removal is probably not in any manual. Image Not Found I discovered that the output of the AX-15 is 23 spline. Of course, that reminded me that ALL AX-15s were 23 spline, it was the early AW4s that were 21 (and the BA-10/5). This is good, if I put my AW4 in the tcase I removed will bolt up to it. Of course, I spun the front output on the tcase and heard some distinct grinding noises, so I think it'll be more like I will use the front input on my other NP231. I pulled the hatch and what little remained in the rear. Oh, and dropped the tank since I didn't want it to go boom when I cut into it by accident. Image Not Found Everything is out that has too be, other than the engine/tranny, the two back windows (I hate glass), the door/hatch seals, and maybe another couple feet of wire and a few odds and ends. I need to cross-brace it a little, then the cutting will begin. But, in due time, I'm out of time off. So, no updates for a bit. -
Started My New Front Bumper Today
DirtyComanche replied to highlandjeeper's topic in Member Projects: Your Comanches
Cool. A lot better than the standard "stick a big ol' peice of HSS on there" style of bumper (which I could be accused of building, more than once). -
Another speedometer cable question?
DirtyComanche replied to xj_dummy's topic in MJ Tech: Modification and Repairs
On the tailshaft intermediate housing (big cone on the back of the tcase). It's fairly obvious when you get under there - there's a bunch of lines running to the vacuum switch on the back of the tcase too, but otherwise there isn't much else to confuse it with. -
Removing speedometer cable from cluster?
DirtyComanche replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
Nah, turns out it's retardedly easy once you get your hand in from the right angle. My cable had almost no slack, you couldn't pull the cluster out more than an inch... But if you go in from beside the ECM you can just give 'er a pinch. Onwards... Now to pull the HVAC apart without wrecking it. Last time I used a sledgehammer. It was fast, but I broke a few things. -
Alright, mine's the nylon type... I'll see what I can do, but I really can't get in there more than anything. Should there be enough slack in the cable to pull the cluster out to undo it? Mine definatly has no slack... I guess I could undo it from the tcase, that has to be done eventually anyways. -
Steal one from the boneyard, and try it. They so rarely go bad that the chances of you getting a bad one are, well, low. Probably as high as getting a bad 'new' one. -
It's probably the emissions one, gets ya a free O2 sensor.
I can salvage it. I can even make it better than it ever was. But I wonder if it is worth it. I'll admit I am partial to the box stylin' of the XJ. For similar reasons, I like MJs. I'd prefer building a MJ in general. Hell, I've already got one that could use some love. But I really felt I needed the SUV instead of a truck for what I wanted. I've talked about doing full frame replacements before. Albiet only for a MJ. Looking at it now, I am very comfortable that I could do it to a MJ and have decent results. The XJ would be a similar process, but I forsee a few more issues. If I go to the effort of cutting it up that much, I will want to change a bunch of other things. I have a rear end that is half built (well, more like 1/4), the intention was actually to use it in this project at some point down the road (I made no mentions of what I'd be doing with the axles yet). You're going to think :nuts: . It's a Hi-pinion D60. Which probably would get me some sort of award for the intention of running 33s or 35s. But, I had no intention of running it with leaf springs in the rear. I also had no intention to keep the front 30, or the 5-link that goes with it. I'll admit it is a very decent suspension setup, and probably could do what I wanted in only a slightly modified form. The problem is that my desire to fix the uniframe will lead me to wanting to do all of the other upgrades at once. As this would only make sense (if I'm going to need a new rear x-member, and a bunch of new brackets, it's best to do them when it is easy). This will consume a lot of time, and necessitate having both of my axles ready to go. Now, how I would fix this (if I do). I think I first need to get the body to a position that it will stay reasonably rigid when the floor is removed. When I say the floor is removed, I mean all of it. And with it the uniframe rails. I'd have to pull the hatch first, and just get it out of the way. Then the remaining interior - which is just the dash, along with all the remaining wiring. And that would be all the wiring. The trick there would be to not screw any of it up. Anyways, I'd need to tack some of my surplus 1x1x.120 HSS in an X brace in the rear and middle of the body, my weld in rockers will already do a fair amount to keep the A and B pillars in position. The C pillar (hatch area) might want to move, and I have few thoughts on how to fix this other than to do some more work on the rear wheel wells before I attempt removing the body. Then I'll just have to cut all of the floor/uniframe off, or at least away from the body, all the way up to the firewall. Then hopefully I can lift the body off and throw it on my trailer (good place to store it, basically). Then, it's just a matter of removing the driveline parts that I'd like to keep (engine, trans, tcase), and rolling the remaining mess outside to steal what little measurements I need, and then send it away for scrap. Then I can get to work on a new frame. 2x4x.120 HSS would be my choice. The shape is relatively easy providing you don't try to copy the factory floor (hence why I'd not save it with the body). Stick drivelin e back in, re-attach body, etc... It'd need a lot more planning to do it that way. But I'm sure it would be unique, if nothing else. -
Well. I think the project died yesterday. I'm actually kinda annoyed about it. It was coming out pretty nice (or so I thought) and would probably have worked well for what I wanted. But, I decided to fix a rust hole in the floor, and removed a bunch of the floor in the process, and yeah, the uniframe is kinda rusted up pretty bad. Not like poke a screwdriver through bad, or even near death bad, but bad enough that I remember why I wanted to build a buggy, or put a frame under a MJ, or generally not work on vehicles. So, it's decision time. I've already burned up half of my time off, and got nothing done. I did a bunch of research today into ubuilt vehicles and the perils of registering them in the fine people's republic of BC. I might be building my own SUV, using the driveline from this XJ and the same general dimensions for the body. Yeah. We'll see how this goes. So, nobody hold their breath for more updates. -
There's also a heat mark on them, uniformly on every tooth. I'm really not sure about that. I want to know what caused this though. I'd say way too little backlash (lack of lube). But I think backlash being too tight would cause the same thing on the other side. The other side is peachy though. I'm kinda preplexed.
Not really, actually. There's a bit of $#!&, but that's normal with gears when they get broken in. All that you see there is dirt, it got in after I pulled the cover. Those teeth have been wiped with a rag, and only have a light trace of oil on them still... But that's the issue. The teeth are brinnelled. It's dun'. They should be shiney, almost polished, in appearance. The other side of them is correct...
So, I had this D44 lying around. It used to be in the front of my MJ. I had no plans to use it again, so I figured I'd sell it. Couldn't find a buyer for the whole thing, but a guy wanted the gears and spool out of it. He offered me enough that I didn't care if I threw the housing in the scrap bin. So, popped the cover to pull the gears out. Image Not Found Image Not Found Yup. Great.
Question about seafoam Need kind of fast
DirtyComanche replied to fatcat0491's topic in MJ Tech: Modification and Repairs
Lots of guys use it and say it was great, so I guess it works... Never used it myself. Probably never will. -
It's some crap that cleans out carbon buildup. Most auto-parts stores sell it.
