Hot Rod Jeep
Everything posted by Hot Rod Jeep
  1. The older MJ and XJ 5 spokes was 7" wide and had a flat outter lip so you could only balance it backside only (unless you wanted ugly stick-on weights on the outside). I'm not sure of the year, but the newer 5 spokes were 8" wide and had an outter weight lip. 8)
  2. Welcome to the club Mr. Cappa. :cheers: 8)
  3. You putting it on your MJ or his vehicle? :D 8)
  4. Well, you replied right before I could and I didn't use the quote button. I was referring to "Asshogger", but you've cleared that up now. :D 8)
  5. Yeah, I agree sweet and scary all at the same time. :eek: 8)
  6. Not trying to argue with you but the shop I worked at always advised against crossing tires like that. We only did it if they absolutly wanted it, it was usually old ppl anyways. 8)
  7. Since it's based on the XJ, think the front end would just bolt on an MJ? 8)
  8. That's just funny. :rotf: :rotfl2: 8)
  9. As much as I'd love to have it, if I had $4,900 to spend I'd have a 401 with a blower in my truck. :D 8)
  10. It's kinda in between K-Mart and Walmart. 8)
  11. Yeah that's a good idea. It took me a few days to figure out what IIRC and PITA meant too, so don't feel bad. 8)
  12. Disco is short for disconnect, or in this case a sway bar quick disconnect. 8)
  13. Since you started it you should be able to delete it. I know the other board I go to that's how it works. 8)
  14. I don't mind black for in the winter months, but not in the summer. Like Cole said, it's too hot in the southern states in the summer to wear black. 8)
  15. I knew some MJ's had them, I didn't know all MJ's did. 8)
  16. Maybe he meant Target? :nuts: 8)
  17. Just throw some stuff in them and claim them as mobile storage units. :D 8)
  18. Someone told me that all XJ's have high pinion 30's, is that true? 8)
  19. Alot of times those guys are idiots and don't know anything. 8)
  20. I'd go locker, but if you can do both then that's even better. 8)
  21. Yeah you'd think they'd learn about their rigs so they can at least fix it themselves. 8)
  22. I know, but I wanted the 1" lift too. I'm gonna be running stock CJ rear springs in the front with a Trailmaster aal and I just wanted the extra inch just in case I needed it. 8)
  23. You call ppl idiots alot on there then? lol I can't believe he thought a full case detroit was weaker than a lock-right and chose Rough Country over RE, he needed called an idiot. :nuts: 8)
  24. Yeah, just can't find enough time to hunt for everything I want on there it seems like. Being broke never helps, luckily my card is deactivated. I'm not real sure I wanted what I was bidding on anyways, it was an ORD 1" block that you could offset the axle up to an inch and a half to shorten or lengthen the wheel base. 8)
  25. Man that is so ghey. You have to answer all questions??? WTF? And just out of curiousity, what did you call them to piss them off? :popcorn: 8)
