87 Comanche dude
Everything posted by 87 Comanche dude
  1. So I thought I had the AX-15, but it now appears that I have the Peugeot BA10/5😡. Where are the fill and drain plugs on this thing? Am I right in assuming that BA10/5s could be in a 1987 MJ 4.0L manual 5 speed?
  2. 87 MJ 4.0L 5 speed manual. So I now see I have an AX-15 tranny. THANK YOU!! where are the fill and drain plugs located? thanks!!
  3. Thanks pizzaman09!
  4. I have a base model 87 MJ 4.0 L, 5 speed manual (No AC). My alternator went out. I plan to add AC this Spring. 1. What amp alternator should I get to handle the load? 2. What amp alternator should I get if I add AC, power door locks & power windows? Thanks!
  5. Thanks 89 MJ & Pizzaman09
  6. A mechanic replaced my ECU in 2012. He got one from a jy. So for curiosity’s sake, I looked at it last week. It has a piece of tape on it that states “AUTO”. I have a manual 5 speed and it works fine, which falls in line with Cruisers posts on the issue. The original sticker number on it is 56006078. From researching comments on this forum dealing with ECU’s, I see that it works fine in my 87 base unit MJ with the 4.0 L. Apparently it’s an upgrade and predecessor to the #’s 428/429’s. MY QUESTIONS ARE: What model year did it come from? Does it increase the HP in the 4.0 L? If so to what HP? Does it have the other improvements programmed into the 89 & 90 models with 428’s and 429’s in them? I just want to know what ECU I have. Thanks for any help!!
  7. I can locate the 2 contact door jamb switch (GP Sorensen JS39). Thanks Wildman! But where do I find the passenger side single contact switch?
  8. Thanks for all of the responses. I overlooked sending a thank you.
  9. Thanks 89 MJ. The junk yard incorrectly stated on the phone that it had an 89 grand Cherokee. That’s why I asked. THANKS!!
  10. I understand the ECU (428 & 429) compatibility between the 89 and 90 XJ’s and my 87 MJ. But………..Will an ECU from a 1989 “Grand Cherokee” with a 4.0 work in my 87 Comanche MJ 4.0 with a 5 speed manual ?
  11. Do any GRAND CHEROKEE parts fit Comanches?
  12. I have a 1987 Comanche with the 4.0L, 5 speed. Does the interior dash from a 1994 or 1996 Cherokee fit my 1987 Comanche? Will a dash from a 1989 Grand Cherokee fit my 1987 Comanche? What years (if any) Grand Cherokee parts fit my 1987 Comanche? thanks!!
  13. What size fuel tanks are available for a 1987 Comanche?
    1. 87 Comanche dude
      87 Comanche dude
      I’m replacing my 18 gallon fuel tank.  Will the 23.5 gallon tank fit in the same location?
    2. ThatJeepGuy
      ThatJeepGuy
      No the 23.5 was a long bed specific tank
    3. 87 Comanche dude
      87 Comanche dude
      Thanks,
      ThatJeepGuy!
