Whitaker717
Everything posted by Whitaker717
  1. I have the non tilt column, floor shifter.
  2. I recently added cruise control to the truck and added the intermittent wiper stalk. I just got an intermittent wiper module and plugged it in and still just have on and off. Do I need to switch something out in the steering column? I assumed it was just a plug and play. If I need a part please include the link to buy it. Would like to have the intermittent wiper function. Thanks guys.
  3. Isn’t that the truth. I just grabbed a couple doorman again.
  4. I have replaced both my running light sockets with the doorman sockets. Upon inspection, the black rubber pieces at the end of the wires close to the socket are all cracked off. Does anyone have any part suggestions besides Doorman? It’s the socket that houses the amber turn signal and running light. Thanks in advance.
  5. Not at first, but due to the freezing cold here in the Midwest I noticed I have a long skinny one now. My truck sits outside and for over a week we barely made it above zero. I will fix it this Spring. I’m pretty happy with how it turned out though.
  6. Yes they are. I had a pair on my 87
  7. I am about to do this preventative measure, any recommendation for a fuel filter? I may do the fuel pressure regulator as well it was seeping a bit of gas around the clip. Thanks Cruiser
  8. I’ll find one eventually. lol. It does still work though. At least for now.
  9. I didn’t think they would be that hard to find. Lol
  10. Thanks I will take a peek. You know me I can’t be taping stuff up. Lol
  11. Think I can find a set anywhere?
  12. That’s a thought Pete. I will do some poking around. I can’t believe someone doesn’t have a few of these laying around.
  13. I have the Hellas in mine as well. You will not be disappointed.
  14. You have a picture of which hose Cruiser?
  15. I have never done that. Is it hard to do? Is there a write up somewhere on how to do that?
  16. Which hose is that cruiser? You have a picture. Can I just blow it out?
  17. I try to keep mine as clean as I can but the edges get soaked. Then I flip it around till it gets soaked.
  18. All those hvac lines are new Napa ones. It did sit awhile but this is my second used engine. I may try the penetrating oil tip though.
  19. Yes I have. Its the most tight fitting of all of them Cruiser
  20. Hey guys like the title states does anyone have any good tips for blowby? I did Cruisers Modification and have all new Napa Vac harnesses. Really don’t want to put an oil catch bottle in there. It is seeping into my air box and I have some oil coming out of the filler cap in the valve cover. Just seeing what guys have done and if anything has worked. Thanks
  21. Since I’m having no luck finding one, does anyone have recommendations for replacement belts that have worked for our trucks? I have an 87 with a bench seat. Thanks
  22. I am looking for a tan, bench seat, drivers side, female seatbelt. Mine is starting to come apart because some of the plastic is broke. It does have the AMC logo on it. I have some guys checking for me but thought I would check just in case. Thanks!
  23. I still have the closed system and there is only about 1/2” filled in the bottle. I’m about 2 or 3” below max line
  24. Thanks for the info! I can just see a max line in my bottle.
