marcial88
Everything posted by marcial88
Can someone post pictures and hose, cables and gas line routing to the weber carb? Will installing the weber make the MJ fail smog test in California? It's for a 2.8l GM V6. Thanks. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
87 2.5 ax5 battery dying
marcial88 replied to Comanche chief 87's topic in MJ Tech: Modification and Repairs
Have the alternator tested. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
Take the battery to an auto parts store if it's good then take the alternator to get it test it. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
Rear slider weatherstrip replacement
marcial88 replied to JMO413's topic in MJ Tech: Modification and Repairs
You can add some black silicone and make it flush as a temporary fix. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
School me on tailgate rubber bumper things.
marcial88 replied to Sir Sam's topic in MJ Tech: Modification and Repairs
Can someone post pictures with the 3D printed ones installed? 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
I have the 86 trim X 4x4, same color same engine but an automatic but no winch. Like you I had to wait over 10 years, 16 years to be exact to get my comanche. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
I recently upgraded my battery cables, you can start there if you like. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
Does anybody have any idea on what these cables plug into? As far as I know, many vehicles rolled off the factory without all the extra stuff but it was easier for the factory just to include the wires and expect for the customers to ignore the wires not connected to anything. Last 2 pictures are the same wires from different angles. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
how many miles on your truck's factory engine?
marcial88 replied to Pete M's topic in MJ Tech: Modification and Repairs
109,078 bought it in May. Havent put many miles in it. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
4x4 shifter will not go back
marcial88 replied to Muncher's topic in MJ Tech: Modification and Repairs
[emoji23][emoji1787][emoji23][emoji1787][emoji23] 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
1986 Comanche Xls Resto
marcial88 replied to 19comanche86's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Unless you do the 97+ front end swap, you can install mushimoto radiator (I think they have the 3 aluminum core) for the fuel pump, well since you're doing the LS swap you're going to have to go all out including the FI part of it. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
Man can't wait for the build. I was thinking doing the LS swap from a tahoe in a year or 2. can't afford an LS1 way out of my budget but I'd rather see your build so I can get a better idea of what tio expect. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
Where'd you purchase the engine/trans from? And if you don't mind, the price? -
cigar lighter plate and aux switch plate combo
marcial88 replied to shipp_m's topic in MJ Tech: DIY Projects and Write-Ups
Can you post the end project with pictures of the exterior lights and the switche? 👍🏽 -
Use the purple degreaser cleaner sold at autozone and other parts store. Spray it on the hat until its dripping, throw in the washer and air dry it. Repeat if needed. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
I always wanted a yellow beetle. Big fan of the G1 Tranformers cartoon. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
Cant find trim retainers
marcial88 replied to marcial88's topic in MJ Tech: Modification and Repairs
Found them. Thanks. Pack of 25 [emoji1417] 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
That's a good idea. I'll find something similar trim if I have to and give it a try. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
I'll head over to autozone o'Reilly and napa later today. Thanks. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
No not those. Thanks though. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk -
Can you post a link to them like Amazon or Ebay please [emoji1417] 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
