marcial88
Everything posted by marcial88
  1. Was wondering where I can find a bundle of these interior plastic trim retainers? Not sure what they're called. About 3/4" long Head about 1/2" 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  2. Have you looked into a higher amperage alternator? 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  3. What type light bulb for the courtesy light? With fog lamp wiring, does that mean I have the wiring for fog lamps? Cargo lights for Cherokee only? How do I connect the ash tray/cigar lights to them? They have nothing for me to connect the wires to. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  4. Have a few cable I need Identifying with. Any help is appreciated. With the radio wires, I see the "AMC" wire harness but plugged into those 2 plugs I see another 2 type of harnesses. Are the second set of plugs the current color coded cables newer radios use? 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  5. Can someone update the pictures? Most old how-to images aren't viewable. Thanks 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  6. Still new here. I don't know how to get to your sig. I'm using the app. I can use the browser too. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  7. I can pretty much buy new or pull a used flywheel from an s10 right? 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  8. Ok. From all the info I've read and correct me if I'm wrong, I can just remove my 86 2.8l V6 and drop a 3.4l v6 right? And swap the carb in and mechanical fuel pump, sensors and wires from the 2.8l? Plug and play? Has one of you guys done the swap on your 86? 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  9. I have ac. I now live in a desert city in Victorville CA. I want to prevent any future overheating. 1986 Jeep Comanche X 4WD GM 2.8L V6 Front: Stock Dana 30 Rear: Stock AMC 20 Los Angeles CA Sent from my SM-G955U using Tapatalk
  10. I have the 86 comanche 2.8 V6. In the future I want to upgrade the radiator to a 3 core aluminum radiator and a heavy duty fan clutch. Can some who has done this or knows about this guide me in the right direction. I was thinking something like getting a radiator for an 85 s10 since. Sent from my SM-G955U using Tapatalk
  11. Thanks a bunch for the build list. You're a real one. [emoji1417] Sent from my SM-G955U using Tapatalk
  12. It was dirty at that time. Washed it last week but looks the same. Sent from my SM-G955U using Tapatalk
  13. I'm looking into it right now and I'm starting to like it. Sent from my SM-G955U using Tapatalk
  14. I bought the comanche a few weeks ago and it came with 31s front and back. Sent from my SM-G955U using Tapatalk
  15. Yes sir. It's an 86. Is the amc m20 any good? Sent from my SM-G955U using Tapatalk
  16. Can someone tell me what I have both the front and rear end? Any good? Sent from my SM-G955U using Tapatalk
  17. I'll check it out. Thank you. Sent from my SM-G955U using Tapatalk
  18. Interior pictures please. Sent from my SM-G955U using Tapatalk
  19. Pictures please. Sent from my SM-G955U using Tapatalk
  20. Previous owner wanted $1500 7 months ago Reach out to her and asked about the Jeep still being for sale. She said $900. I went the following day to see it. Asked if they want $900? They said they'll take $800. I offered $700 and I'll pick up the following day. Now its mine. Previously it had been parked since 2008, so I was told but that it was running before it was parked. I towed it home and put a battery in and some fresh 91 gas. Eventually I got it to turn and it purred really good. I then realized it was leaking coolant. I found it leaking between the motor and the transmission. Freeze plug??? I also did an oil change when I caught a strong smell of gasoline in the oil. Leaky/bad carb??? That's where I'm at at the moment. Want to get the cooling fixed and possibly have the carb rebuilt. Sent from my SM-G955U using Tapatalk
  21. Year, Make, Model. 1987 Jeep Comanche X GM 2.8L V6 2BL Automatic 4X4 I don't know how to tell what kind of transfer case, front/rear axle Build date: Date Faded Away Current Location: Victorville CA Status: Non-OP, Project, Parked on front driveway As far as I can factory Skid Plate Cloth Bucket Seats Sand Color Interior Tilt Steering Wheel Floor Shifter with Center Console Silver Exterior (needs new paint job) Long Bed Current owner: I'm the current owner. My new project Sent from my SM-G955U using Tapatalk
  22. I have an 86 2.8 v6. I can take pictures and send them tomorrow.
