OldSch88L
Everything posted by OldSch88L
  1. Well, I went through your master index twice and couldn't find it. In fact, any info on that quartz clock with that particular blue connector is scarce even on the web. Most people seem to have the one with a black connector?
  2. Little update on the fuel gauge swap. I've put the Renix gauge in the 1996 cluster, held on by the 3 gauge screws/contacts and wired in the brass tabs correctly. The gauge worked, but the low fuel light was always on. Turns out the Renix gauge has a second, separate PCB hiding behind the tach, inside the cluster case. It's held on with 4 screws/contacts, so I took it out and grafted it in the 1996 cluster, and wiring it in. All seems fine now; I'm just waiting for the fuel to get low enough to make sure the warning light works. If it does, I might make a how-to about this whole thing. Why all this trouble you ask? I couldn't stand the jumping needle from the cable driven speedo. Also, all the full clusters I could find were the electronic ones. I already had a speed sensor from a spare transfer case, so I did the electronic speedo conversion. Then, the reverse-reading gas gauge got on my nerves; so it was either finding a 1991-1992 fuel sender, or swapping in the Renix gauge and components to go with my existing Renix sender, which I got from a Renix full cluster that came with my new dash, so there we are!!!
  3. Finally figured the clock on my own. For those interested, the wires coming out the clock are: Red Constant 12V Black Ground Blue Acc 12V Yellow Park Lamps (usually the orange/black tracer wire in the dash) Orange Panel Illumination ( was a blue wire in my dash, varying voltage controlled by the light switch's dimmer ) Hope this saves the next person some time!
  4. I guess that's not far from the truth... Another curveball I had was that all the diagrams I could find said that constant 12V in the dash was the red/tan wire, while it's a pink wire in that XJ dash. The only thing left figuring out is the darn clock wiring because neither the wiring nor the connector match any info I could find...
  5. Well, I finally found the culprit; turns out XJ and MJ dash harnesses aren't always plug and play. The wire that feeds power to my particular XJ dash's dome fuse, red with white tracer, comes to a dead end on pin A6 on the XJ bulkhead connector, while it's actually on pin D4 on the MJ connector. Weird...
  6. Well, it's a Renix era; the seller tought it was an '88 but wasn't sure, as he got it from a parts stash included with an XJ project... But I'm pretty sure I saw a 1990 date stamped on the cable-driven cluster that came in it.
  7. I got my new dash installed and was testing everything before the final reassembly. Pretty much everything works, exept B-pillar lights, footwell lights and the clock acted up. They barely worked intermitently, the lights being a dim orange. Now, none of them work, including the glove box light. The radio works but has no memory, and these results point to the dome fuse. All the fuses are OK, and I pulled out the dome fuse and put my multimeter leads on the fuse box terminals, and there's no power, while it should be hot at all times. I swapped the XJ dash with its as-new harness and fuse box following an how-to that I found here to match the wiring to the MJ. Could it be the black tar-like goo at the firewall fusebox connector causing trouble, or a fusible link somewhere? I tried everything I could, but electricity and wiring is not my cup of tea (translation: I freakin' hate it!) hahaha!
  8. Here are the part numbers for those interested; the sensor is a Delphi unit.
  9. So I went with a GM #2309506751-equivalent sensor from Rockauto with matching pigtail. I installed it in the airbox lid, and with the truck sitting for a while, I got a 63 degrees F water temp and about 61-62 degrees F air temp readings according to the REM, so way within the error margin IMO. Looks like a worthy replacement!
  10. To make it short, both gauges have the same contacts on the PCBs. It's just that the Renix and 1996 are printed differently. The 3 center screws line up, but the brass tabs on the renix gauge don't, and make the gauge stand out too much since the 1996 cluster case is shallower. So, the tabs also being contacts, I cut them and soldered wires and routed them to their respective places. If it works, I'll take the cluster back out to show pics of the final setup.
  11. The 1996 fuel gauge reads backwards in my 1988 Renix Jeep. I wanted to keep the electronic speedo so I modified and grafted the 1988 fuel gauge in the 1996 cluster. I'll test it in a feel days to see if it works.
  12. I'm currently swapping a really nice 1988 dash that I found on marketplace to replace my old cracked one. It also came with a full cluster. However, I previously swapped and made the proper mods for a 1996 full cluster with electronic speedo. The downfall was a reverse-reading gas gauge. I didn't want to deal with finding a 1991 MJ fuel sender, so I took the gauge from the Renix full cluster and did some slight mods, then installed it in the 1996 cluster. I tought some of you might want to see the differences between the two; they share the same gauge, but way different PCBs. So I guess there's more than just different senders. However, the Renix one being so simple, I'm sure one could take a 1996 cluster and convert the gas gauge to Renix duty...
  13. Here are the be all, end all videos about 5X7 lighting. These guys seem to know their stuff and do thorough testing: https://youtu.be/xWT5h-WWHTU https://youtu.be/6ifsEY7KbBg https://youtu.be/zwQs7uyGFvs https://youtu.be/vCNj9hvPSfY https://youtu.be/W1JtVou4pSY
  14. I'm in the process of doing this. I've got a GM (Delphi) sensor and pigtail on order due for next week. I'll get back with details when it's done.
  15. I was thinking about it, but wondered if it was worth it since I get no reading from it... Wouldn't a dirty sensor at least have a little resistance? Mine actus like an open circuit...
  16. So I didn't waste any time and put my new REM to work and found out the IAT sensor is pretty much dead. The REM constantly reads 246F, and my multimeter can't even get a resistance reading out of the sensor. I've read elsewhere that there's a GM sensor that's pretty close in terms of specs and ohms. Anybody ever tried it?
  17. Time for some updates. Got some progress on the roll bar restoration. Parts are held in with sheetmetal screws and will be ready for welding. My original dash started cracking a year ago, so I was actively looking for one. Stumbled on an unassuming ad on marketplace for an XJ dash with no price and 2 bad photos. Chatted with the guy, and long story short, he's a total Jeep nerd, and the dash was pristine and came with a Renix full cluster, unmolested dash harness with as-new fuse panel, and sentinel module. Even better, turns out the guy also had a R.E.M. II+ for sale that he forgot to mention! I tried to buy a new one a few weeks ago but Nick said he was out of stock and waiting on the chips for the next batch, and couldn't give me an E.T.A. So, to find a used one is a Godsend! All those goodies for 250$CAD (197$USD)!!! So, I'm already solving engine gremlins thanks to the REM, and getting ready for the dash and harness swap. More pics to come!
  18. Most of my favourites have been said, but I also like Ronin for the somewhat honest looking car chase, I also kinda like the Initial D movie even if it's cheesy, and finally, the funny french movie trilogy, Taxi, Taxi 2 and Taxi 3 if you can find 'em with subtitles. I've seen them on Netflix once, but they haven't been back for a while now...
  19. Thanks a lot! It's slowly getting there! I painted the wheels and grille so that they complement the charcoal and silver Pioneer stripes I'll put back on when it gets repainted in a couple of years; can't wait!!!
  20. It's at about 3/4of the way forward right now.
  21. Well, I got it figured out, and the truck runs real nice, but someone, somewhere, made a mistake. The second hole on the camshaft is a smaller and tapered hole, and the dowel doesn't fit, which means it was where it should be. However, when the cam and crank gears line up their respective dots, the #1 piston is at TDC on the exhaust stroke, and not compression like everyone, including the Haynes manual, want you to beleive. The distributor lines up at cyl #4, and the exhaust lobe on #1 points straight up. I tried the distributor pointed a cyl #1 with the dots lined up and it wouldn't start, but pointed at #4 it runs perfect.
  22. You can see the two holes in this video from Nickintimefilms at 13:38
