Everything posted by rosco11
A couple of misc steps on the Comanche before we get to some major component upgrades. My brother helped relocate the rear brake line mount and drilled and tapped a new spot. The suspension lift we are using has wider frame brackets so I needed to notch-out the side frame support. Got this all done and cleaned, primed and painted
More new parts to fix up the Comanche! We are installing the 4wd cable shifter. The original 4wd linkage is temperamental and sometimes works and mostly works against us trying to shift into 4wd. It's a fight! We got rid of that headache and frustration and added this Savvy Off Road cable shifter. The mounts are robust and hardcore while the stout cable shifts like butter!
On the Comanche, we took advantage of the time with the rear axle out. Primed and painted the new gas tank, gas tank skid plate and UBolts.. it started raining so had to rapid transfer into the garage and make do with the space I could find
Comanche axle is out, we set up the proper pinion angle with the new drive shaft and tightened the UBolts. Got the spring perches welded in place. I'd like to take credit for the awesome welding here, but we decided to take it to some pros that my brother knew. I'm sure they were very impressed with my tack welds!
Awww Yeaaaah! More new parts showing up! The Adam's team made this driveshaft perfect, added the Ford 8.8 conversion flange and balanced it before shipping out! We set it up and measured the pinion angle before we weld on the spring perches
Sad face is right! It's a lot of work to fight 30 yr old rust and then try to prevent! Please let me know if you see me doing anything way wrong during all my updates! Your advice would always be appreciated Sent from my Pixel 3a using Tapatalk
We got the Comanche console installed! Because it originally didn't have a console we were missing 2 of the 3 mounting points. I ordered the upgrade metal mount from JCR off-road for the rear and then we created and welded the front mount from some stock flat 1/8" steel. Drilled holes for the mounting screws and used Uclips to screw into. As everyone says that JCR mount is really well done. We had to bend and fit it to make it level and expand the mounting holes for the bolts we wanted to use. We drilled through the trans tunnel and inserted bolts up from the bottom, washers and nuts on top and then covered the bottom with silicone under the truck. Bam! new center console!
This is back dated a bit... but it was very exciting to start receiving new to me parts for install instead of constant rust fighting! 97+ Cherokee console because I sold the bench and went with buckets
On the Comanche paint and rust protect project.. got the entire underside painted with Rust-Oleum Pro Enamel. Also, based on a great recommendation from an experienced Comancheclub member @Jeep Driver, I added majic catalyst hardener in the paint mix. It finished super nice and smooth and much harder than other parts I've already coated.. Sweet! ... And we reinstalled the NP231 transfer case with Slip Yoke Eliminator
Finishing up the drivers seat mount on the comanche. The longer side tab was completely gone. Cut out a piece of metal in the shape l thought would work and welded it on. Test fit for the proper height in the truck and made a few adjustments with the grinder. Once I was happy with the height and it made the seat level, I made a side brace for stability and a small bottom tab to bolt to the floor. Used some rust converter paint and then a good top coat. It's very cool having the seat in the truck.. first time putting in the bucket seats since taking out the bench seat. Seat Project done! This comanche project is not officially sponsored by Dr Pepper or Coca-Cola, but if they're interested!?!?
This is part of the Comanche project I've been absolutely dreading. Grinding and wheeling rust and flaky underbody coatings. Luckily above the transmission was in great shape but around the floorpans and above the muffler was pretty bad. It was a dirty dirty job! Under the truck grinding in very tight spots.. not much was fun about this part, but just got under there and got after it!
Thanks WSteeler! I appreciate you saying that! This particular MJ has a ton of potential to be a solid truck for a long time. It's the hope that it'll be a great ridin truck, restored and built well is what keeps me going! Stay tuned, more to come!
Man I hope not! I turned a GMC Sonoma 4x4 into my hunting rig out in SW Texas. We put a small suspension lift and fixed a bunch of pretty bad rusted areas. After fixing and fabbing and welding, I just rustoleum sprayed everything and it looked perfect. Well, fast forward 9 months.. 14 months later and rust was poking through all those painted areas and rock chips rusted again. I'm hoping to do things right on the rust fixin and prevention on the MJ!
Finishing the bottom side of the Comanche bed, wire wheeled loose rust and debris, 2 coats or rusty metal primer and 2 coats of rustoleum pro enamel.. Done! It looks so good.. when this is all done I might crawl under the truck just to look at it sometimes!
Moving onto the Comanche bed, we had 4 broken rusted bolts to extract or fix. We fixed by cutting them out, fabricating a square piece of metal and welding a nut to the backside and then welding them back into place. Turned out much easier than trying to extract 30 yr old bolts
Thanks Buck! My brother has been helping me throughout on some of the projects. I have to balance him wanting to build up and make off road awesome and taking time to restore issues like this and rusty panels and mounts and brackets.. either way it's been fun and lots of learning. Thanks for checking it out.. more to come! Sent from my SM-G930V using Tapatalk
Now on to fixin the seat mount tabs.. they were rusted and broke and likely not safe at all. Made a template, cut out new steel tabs and drilled the holes to match. Had to re-fab 4 of the 8 tabs for the two seats. Rust is terrible and unforgiving..But we got it done! Sent from my SM-G930V using Tapatalk
Very cool part of the Comanche project I've been waiting to do. Sometimes a little comfort is worth the effort! Added carbon fiber seat heater pads to the bucket seats.
While waiting on paint to dry... Pro tip: to save your paint, double up 2 layers of Saran wrap and install the lid over that, hammer it down! Sent from my SM-G930V using Tapatalk
Yes sir.. i am going with new carpet and upgraded backing. I've put so much time into the floors i don't think leaks could get in.. fingers crossed! Do you have a build project thread? I'l check it ot if so! Sent from my SM-G930V using Tapatalk
Just my luck.. Cuss Word! Cuss Word! Cuss Word!!!.. Dang! While grinding the flakey terrible rubberized coating underneath I found this hole, you couldnt see it.. it was covered by the coating underneath and the seam sealer inside. It's in a complicated spot too. Two separate metals overlap right there, the floorpan overlaps above and the fender well metal on the bottom. Took some thinking and a few beers to figure out how I was gonna fabricate a fix. I cut out the bad and started making templates out of a 12pk Dr Pepper box. Traced it onto metal, cut it out and started shaping it to match the bends of the area. Got it welded back in and seam sealed it up. Rough project I didnt know was coming! Guess that's how it goes on a 30 year old classic Sent from my SM-G930V using Tapatalk
"Wendy"- 88 Jeep Comanche Build
rosco11 replied to Swampy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I've never done a swap but if you decide to, I'll certainly follow and I know you'll put in the effort to make it work and be better than before.. let us know what you decide or find out about the 2.5 Sent from my Pixel 3a using Tapatalk -
Got the Comanche floor top coated with Rustoleum pro. Looks freakin awesome! Sent from my SM-G930V using Tapatalk
We'll keep moving forward on the floorpan project, went ahead and put on Rustoleum Professional Rusty Metal Primer across the whole floor and transmission tunnel! A few more steps and we're done with floors!
