Everything posted by LEAD_NOT_FOLLOW
Yes...
Oil Pressure and Engine Options?
LEAD_NOT_FOLLOW replied to GirsMJ86's topic in MJ Tech: Modification and Repairs
How are you verifying your PSI? The 4.0L is known to have faulty sending units to the gauge. To check the gauge turn ignition on (do not start) and needle should go to zero. Unplug at oil pressure sending unit and gauge should go off scale to the right if the gauge is working. Most likely it is the sending unit. However your numbers do not sound bad. If you "punch" it and it goes up thats normal. -
Read up, recently talked about... http://www.comancheclub.com/forums/view ... 3&start=45
1990 AW4 spline count
LEAD_NOT_FOLLOW replied to JeepcoMJ's topic in MJ Tech: Modification and Repairs
The year was '90. Early '90 had a 21 spline, late '90 had a 23 spline. So saying a '90 is 21 spline is not always true. For instance our '90 has a 23 spline. "Lead_"I've been through 4 AW4's in my XJ"_Follow -
New 2.5 MJ project...Now a 4.0 H.O. project
LEAD_NOT_FOLLOW replied to CEThomas's topic in Member Projects: Your Comanches
Glad ya guys made the trip ok and fit it all in. It was nice putting a face to a name :cheers: -
XJ axle on an MJ
LEAD_NOT_FOLLOW replied to Chase The Hero's topic in MJ Tech: Modification and Repairs
Front or Rear? -
MJ 3800 camaro powered
LEAD_NOT_FOLLOW replied to JeepcoMJ's topic in Member Projects: Your Comanches
It says Kyle is Pretty; matches that purple roll-bar. ;) -
Towards the bottom of the page. http://www.motionoffroad.com/suspension.html
Those are the rails on my XJ. Let me know if you want/need any other pics of them.
I don't think Wade will be cutting his rockers out anytime soon... That being said, I think he's going to build something more "bolt on". I'd use at least 3/16" thick tube. Also make sure you make a bracket to attach to the pinch seam to help spread the load if you do come down on them hard. Nothing is worse than having a set of rock rails and coming down on them and having it tear up your rockers more since you have them.
http://formattfab.com/product_tube_door.htm info@formattfab.com Rumor has it though that Matt stopped making them. You'd have to email him directly and ask. Also just a FYI, any XJ 4 door front tube doors will fit an MJ.
I have no personal experience but rumor has it that the mile marker kits like to fail. Like I said, no personal experience but I've seen pics of them in the past totally trashed. If your going to spend the $$, go with Warn as they are tested with good results.
i need help with decisions
LEAD_NOT_FOLLOW replied to manche0230's topic in MJ Tech: Modification and Repairs
The XJ and the MJ are 95% identical from the cab forward. What is designed for the XJ is designed for the MJ as long as it's the cab forward. -
Cutting lowers off of bed sides
LEAD_NOT_FOLLOW replied to oldjeep's topic in MJ Tech: Modification and Repairs
Stock front flares, TJ rear flares on the rear. -
Pssshhh! Couldn't of climbed that rock pile with BFG's. ;) I came from BFG's to the Bighorns. Won't ever go back... :D
I ran the Pro Crap MT's a few years back. I think they've probably changed the design a bit since I purchased my set. Tire wear was ok, not the best. They were loud on the road. Offroad they performed ok as long as you didn't get them wet. Wasn't a bad purchase, but probably wouldn't buy another set if I had to. However that looks like a killer deal, hard to pass it up... -Lead_"Anyone who knows me knows I'm anal about tire performance"_Follow
35x12.5x15 Maxxis Bighorns -
Here you go. :cheers: http://greatlakesxj.activeboard.com/ind ... D=11043614 -
Power/Comfort switch.
LEAD_NOT_FOLLOW replied to Mobius1's topic in MJ Tech: Modification and Repairs
For future reference. http://www.greatlakesxj.com/tech/TCU4.jpg -
They are LaBarron hood vents. I have them in several of my rigs. -"Lead_"I always have a set of vents for sale"_Follow -
I just cut the rear lower's off. If I didn't they'd be smashed up from wheeling. A few pics: -
Once again a great weekend at the Badlands. A bit cold, and rainy at first, but ended up to be a good day for some wheeling. For those of you who came, thanks again for coming. Those of you who punked out again you missed a good time. Here are some of the better MJ shots. We have another 125+ photo's on our website; you can see them by clicking here: http://greatlakesxj.activeboard.com/ind ... D=14023226 Onto the pics... Group Shot of 4 MJ's. Bob crawling the rock face. Adam doing the same And also Wade doing it Adam will flex on anything he can find Adam lifting tires Adam crawling the rock pile Wade getting muddy Wade in the rock garden LOTS OF GOOD PICS ON GLXJ, BE SURE TO CHECK THEM OUT AT THE ABOVE LINK!!!
Turbocharged 4.0L?
LEAD_NOT_FOLLOW replied to jtdesigns's topic in MJ Tech: Modification and Repairs
It won't fit under the hood on the XJ or MJ. I have the KB setup on my Golen 4.6L stroker in my XJ. I had to have a custom set of motor mounts made to lower my motor 1.25", do an adapter plate for my intake manifold to lower it .5" and than have a custom pulley made to get the rest of the clearance with the hood. If you factor in the blower, I have around $6K in the project, not including the cost of the engine management. Took me 2 years and it's finally on as of about 3 weeks ago. Search Jeepforum, I have a lot of pics and info of my project.
