Jackrabbit41
Everything posted by Jackrabbit41
  1. So ever since I swapped my trucks been running horrible. It does every time you let off the gas, at idle its like it had the worlds biggest cam. All the lights dim and brighten as the engine revs up and down and the thing smokes like it's running off sea foam. I never touched the engine. Would could this be? It's making new noises too
  2. Does anyone run any sort of roof rack or headache rack or chase rack? I want to make my own, just trying to get ideas. Google images doesn't have many pictures of Comanches running that stuff. I want something someone and none flashy
  3. I need to replace the drivers side motor mount. I just bought a stock one. Can I just go from underneath or do I need to remove the intake and header?
  4. I put in the wrong flywheel on so I had to pull out the tranny and swap fly wheels and then put her all back together. Running good and shifting smooth. Sent from my iPhone using Tapatalk
  5. The flywheel I used to have was from the 95 and never had any problems with it. Are you saying that I need to swap flywheel or do I need to go to Napa and get a 95 cps?
  6. Yes I did with the exact same one Would I need a cps for the 95? Not my 87?
  7. So just finished tranny swap and now she won't start. She turns over but not firing. My cps was good before but I changed it out anyway thinking it'd be the problem. The thing still won't start. what should I look at next?
  8. Second ax15 swap in progress. So far smooth sailing. Just need to bolt on bell housing, shifter, fork and bearings then re seal the transfer case and she'll be ready to go in! Sent from my iPhone using Tapatalk
  9. My new ax15 came with this seal. Can't find anywhere for it? Any insight from y'all? Sent from my iPhone using Tapatalk
  10. I just sea foamed my tank and then got the intake cleaner too. I just did it because j felt like it
  11. I'm about to do this, I'm interested as well
  12. Just wondering what other parts j should swap when doing my tranny swap. I did this 1 year ago so that's why some things aren't on the list: Throw out bearing Pilot bearing Re seal t case (leaky) Input and output t case seals Flywheel (bolt holes could be bad) All fluids related And also, what do I torque the clutch bolts down to and the flywheel bolts? Don't remember ...
  13. Not sure but I've bought 3 pre bled kits and they've always been perfect. On mine there is a hex screw that looks like a bleeder screw
  14. Falling out as in lose bolts I think
  15. what do you mean your flywheel is falling out?was it not torqued properly on instalL? :P I torqued it to the correct spec last year when I swapped my tranny but it's coming out. I can wiggle it by hand. And my current trannys really leaky and has a bad synchro or two also, hiding the RC doesnt change anything unless you swap to something other than RC!!! keep up the good work I torqued them down to spec but obviously something isn't right haha
  16. Should I get a new flywheel or use the one I have? Mines falling out so it could be damaged. I don't have the time to get it re surfaced. Thanks
  17. Flywheels falling out so ordered a new tranny last week, actually a reman, so this weekend I hope it'll get here so I can swap it in with a buddy and get the jeep goin again!
  18. So when I did my ax15 swap last September I just had a bushing made. I'd like to have an actual bearing. I've heard of guys using some bearing from like a 304 or something I don't remember. I have a 87 renix and my trannys from a 95 Cherokee. The stock renix bearing doesn't work and the stock ax15 bearing doesn't work. Thanks
  19. i need to paint that steering stabilizer. I hate having anything that says RC on it lol
  20. Sent from my iPhone using Tapatalk
  21. Forgot to post final pics my bad Sent from my iPhone using Tapatalk
  22. So I ordered a reman ax15 and on the phone call they asked me how many bolts on in the transfer case shifter. What did they mean by that? They might call me again this morning asking it again. There was another question too by I can't remember it
  23. Sweet. Just called them. gonna be 1400$ with a $300 core. That's all my money lol. I've been saving for a dirt bike so that's not gonna happen
  24. this one says its for all, will it be the same thing? just cheaper. http://www.ebay.com/itm/301673766523?item=301673766523&frommaketrack=true&viewitem=&vxp=mtr
