Everything posted by cbreiter
UPGRADED front end/steering components
cbreiter replied to projectMANCHI's topic in MJ Tech: Modification and Repairs
Got myself a newer pump today with what looked like fairly new hoses. Hope it fixes my leaks up! -
Brake booster, will a '94 Cherokee one work?
cbreiter replied to cbreiter's topic in MJ Tech: Modification and Repairs
Got my WJ booster today! -
Jeep Grand Cherokee issues
That kinda what I was thinking. That or a almost plugged fuel filter. -
Sorry if I put this in the wrong spot. -
I'm looking at getting a grand Cherokee for a winter vehicle, but the one I'm looking at has some issues. Apperently it loses power and bucks under load, and can't go any faster than 20km/h. Could the MAP sensor cause this? It's a 4.0 litre, with auto trans, and is 4x4. Here is a link for it: http://www.kijiji.ca/v-cars-trucks/saskatoon/1995-jeep-grand-cherokee-suv-crossover/1049553048?enableSearchNavigationFlag=true
I use mastercraft (Canadian tire brand) 20 volt lithium ion. I have several drills, impact, and a saws all. I haven't had any real issues with any of them, and the batteries work good, had them for 2 years now. One thing about li-ion though, they don't like cold temperatures. Other than that I couldn't be happier with them. Especially seeing as how they are quite a bit cheaper than the big name brands.
That's true, but the filter shouldn't be discounted. It still makes a difference. The better your air delivery, the better other mods work.
Engines tend to run fine with the factory setup, however usually a standard filter doesn't allow as much airflow as is possible, that's why adding a higher flowing filter will gain you mpg, and hp. A cold air intake simply takes it a step further, with a cone filter usually. This setup will simply maximize the amount of air your engine can pull, with the factory setup. Just my 2 cents on it. Usually more airflow makes more of a difference coupled with a freer flowing exhaust, and more fuel.
Renix To Ho Tps Adapter
cbreiter replied to ftpiercecracker1's topic in MJ Tech: DIY Projects and Write-Ups
anyone have this thread downladed with all the pictures? -
Who has over 200,000 on a daily driver?
cbreiter replied to 88AMComanche's topic in MJ Tech: Modification and Repairs
I've got about 250,000 miles (over 400,000 km) on a '95 Ford Taurus. Someone I worked with parked their '91 at around 500,000 miles (over 800,000 km). She's a work beater, but runs good and doesn't seem to use any oil. The major deciding factor will probably be how long the body lasts. -
Alright! I'll see what I can find the next time I'm at the wreckers. Sorry for kinda hijacking the thread. -
What would be a good option for me that would be a bolt on? -
I guess I should have said the truck is a 4.0 litre, 2wd. I'm mainly looking for bolt on junkyard swaps. Hornbrod, did you swap over the lines with the new pump? And was it a direct bolt up? I guess I could just replace the pulley on mine, but it has a loud whine all the time, I put some Lucas power steering conditioner in it, and it's some quieter, but it bugs me and I don't want it to go out on me. -
I'm looking to swap out my steering box to the quick ratio one. Does the pump switch over too? Just wondering, Cause I was working on swapping out my sway bar, when I noticed that my steering box was leaking, and the pully has a small piece gone out of it on the pump. Anyone know what hoses are best? -
Yup, that's what I'm planning to get -
Goodyear Gator Back belt squeal
cbreiter replied to hillbilly51's topic in MJ Tech: Modification and Repairs
I've used them on my '95 Ford Taurus and never had an issue. One thing to remember is that once a belt slips for a while it tends to get a glaze to it which makes it slip easier. I personally prefer the prestone belts. They seem to be good quality. -
What is required to make a WJ one work? Just thinking newer is probably better. -
Ok, thanks for letting me know. Just had seen someone on here swap a '92 booster in, so I assumed they must be a dual diaphragm. I'll just have to go get the right one. -
That may be true, but the whole point was to gain some power and a bit of gas mileage. I'm thinking either a new carb, or a rebuild kit for this one will definitely help out. The idea has been floating around in my head for some time of putting a 360 in it though. Maybe after I get my comanche all fixed up and going so I don't have to drive longer distances with this one.
What do you want to know about it? PM me for more details.
It probably wouldn't help that I run 31's on the truck either, at least for making it less of a dog anyway.
Alright. I'll see if I can get a better carb for it. And yes those doors are massive
They are nice, but can eat up a lot of money in a hurry, lol. The pop up lights look nice, but can be major pain to fix. Leaky t-tops is usually the nature of the beast until you replace the weather stripping too. If you're looking at one, make sure the steering box doesn't rock too much, it's a weak point in these cars. If driven too hard the frame fatigues there and will flex a lot. Some of the cars had extra bracing to fix that, but others didn't.
