Roost426
Everything posted by Roost426
  1. I get so excited when I see a fellow MJ while driving mine and the head turns and stares from some XJ drivers is great
  2. Hadn't driven the old gal for a bit, got her out for the snow and you know I am representing
  3. Finally replaced my rotted out rear bumper with a Fey, digging it! R.I.P Rusted out factory bumper
  4. Hey all, brakes felt funny other night. Popped master lid, front reservoir was empty, Filled it up and pedal still feels great. Everything at the back wheels is dry. There is fluid oozing out down the front of the booster and its all corroded/rusty. Has just my seal failed and I will be ok with just a new master or also a new power booster? The master run only 20$ or so but the booster is a bit pricier.
  5. Check on the hose from the MAP Sensor to throttle body, was having a somewhat similar condition and mine was cracked right near the elbow where it pokes into the throttle body.
  6. Check the tps voltages http://cruiser54.com/ #8 Also check the hose from your'e map sensor, I was having an issue and checked all this and even replaced my injectors with the better volvo ones and it ended up being the map hose had cracked at the elbow where it goes into the throttle body and was causing some serious running issues.
  7. yep yep, mine kept messing up and I kept thinking it was the delay module turns out it was that circuit breaker being a bit corroded from our good friend mister master cylinder leaking some lovely brake fluid onto the back of the fuse panel =[
  8. Yea I see a few driving around the valley area here rarely, and no I didn't have any cards to leave, but I am going to get some for the next comanche encounter !
  9. Today I spotted a fellow Comanche in my small town, hung out for a bit but the owner didn't show. It wasn't one of you fine folks on here was it? Anyways nice truck!
  10. http://www.jeepsticker.com/comanchesidestickers.htm
  11. So I look over towards my mirror to switch lanes and am greeted with this :doh: Apparently it decided to fall off somewhere and will never be found! Any places to sort new glass for it and what else is missing from it? From looking at the other side there is also a black rubber gasket on outside not sure if it would come as part of the glass.
  12. Ok 2nd update of the day and its a good one so far. Tested TPS. Reference voltage was 4.87, output was .33 not good.... So 4.87 x .17 was telling me I need .82 output. Adjusted it to the .82 started and idle was high but test drove and all was good, pulled over and turned it off, restarted high idle was gone but missing/lurching was back :doh: Drove back home tested output again and it had moved to .85, readjusted back to .82 and tightened down better, after 2 test drives now it has not high idled and the problem is cured as of this moment, Time will tell though :laughin: I really don't know what I would do without all the info you guys have compiled here it really is a life saver. thank you! My idle does seem to wander just a tad, not a lot, honestly I probably won't even bother chasing that right now as long as its running well.
  13. Alright update time, finally tracked down the vacuum leak, it was small hard plastic vacuum line that went to what I believe is the cruise control, had melted through on something. My idle seems to sound better but I still have the really bad miss/lurch. I did a fuel pressure test and I am showing 30 psi and 38 with the vacuum line removed so I think things are inspec on that front? I am starting to feel like maybe I have a bad injector? A couple of them had alot of junk built up around them and inside their port on the intake. Going to do a compression test this morning and TPS to rule those things out.
  14. Yea going to hunt around for it some more today, hopefully it is my issue. I am having a horrible misfire/stumble when any more than like 1/8th throttle is applied, but the truck will continue to accelarate while stumbling badly. It started doing this a week ago, put new plugs and wires and also a fuel filter the old one was very occluded. Fixed the issue for a bit, then a few days late it started acting the same. I checked the fuel filter again and it was VERY hot to the touch so I figured my exhaust leak had finally got to far out of hand and was heat soaking the fuel line. I replaced the manifold and the truck is is great now quietest it has ever been, but the bad stumbling/missing issue is still present. A couple times it has completely stopped and ran fine for 5-10 minutes but comes back suddenly. Possibly the clogged filter or heat soaked fuel caused damage to the fuel pump? I will be on a wild goose chase for the issue this weekend. Interesting thing, while tearing it down to replace exhaust manifold I noticed the end that screws the EGR pipe into the intake was just hanging down on the elbow so the end of the egr pipe was loose in the intake and obviously not sealed.... not sure if previous owner undid it or it somehow backed out. My exhaust manifold was cracked so badly that the entire furthest back pipes weld was completely broken all the way around only the thick flange was still holding it to the manifold assembly.
  15. Hey all, chasing a gremlin that my truck developed recently. Quick question, should I hear an audible vacuum/air sucking sound from the area of the charcoal canister? then it dies off 3-4 seconds after motor is shut down. It happens during idle and revving no audible sound change. Trying to figure out if I have a vaccum leak somewhere in this area. Undoing the two hoses ontop of the canister seems to make no difference.
  16. Yea, I decided to just go ahead and order it all, got the timken unit bearings and spicer u joints on the way from rockauto. :cheers:
  17. Hey guys, I recently developed a noise/vibration that seems to be coming from the passenger side front tire area. I swapped tires front to back to rule out an out of balance tire/bent rim and my tires are close to new anyways. My buddy and I seem to be thinking it is either a wheel bearing or the U Joint. When I get to about 40 mph you can start to hear a noise, and while turning it seems to increase the noise and I can feel some pulsating/shimmying through the steering wheel, and even the whole truck seems to vibrate some what, not super violently but it is there. Also it seems to be worse/louder when I turn right, which is actually unloading the weight off of the suspected area. When I jack up the front that wheel does not seem to have any wiggle in the 12/6 vertical position, which I had heard wiggle here would be indictive of a wheel bearing. Any other ways I can trouble shoot to try and single out what the issue is? Else wise I will just bite the bullet and go with new wheel bearings and U joints for the front axles.
  18. Bought the truck for $1600, probably about $500 worth of parts replaced and ~$700 for new tires, lets call it $3000 so far.
  19. I need to try and tighten the passenger side one or I might need a new one, it wobbles on the socket and won't hold position, last time I tried to move the 2 screws that I think tighten it they didn't want to budge!
  20. Very cool, I guess that explains why I have the D44 and non metric ton springs. I haven't seen another Comanche on here with these side mirrors they must be part of the tow package? Also does anyone know if I will be able to keep my stock tow hitch on with an aftermarket bumper like the Nates 4x4 or JCRoffroad?
  21. Fromy my calculation's I have been steadily getting about 19-20 mpg, this is mostly driving around backroads 40-55mph and some city driving. I am running 235/75/15's and have a pretty bad exhaust manifold leak at the moment so not sure how those are affecting thiings. My truck does not like to pull 5th gear until 45mph, seems to boggy below that.
  22. Very cool! Will be a nice sleeper.
  23. Don't tempt me haha, I was just looking at this truck this morning on Clist! He says he will trade for firearms, but I have a tough time parting with mine :thumbsup:
  24. Here she is a couple weeks ago, went out playing in the snow. Just been fixing some small things, I replaced the tranny mount, motor mounts and O rings for the filter adapter. Installed a new water pump,also replaced the crankcase vent hose as I discovered my air filter drenched in oil and I could not blow any air through the old one, so far there is much,much less oil going to the air filter, but still some, so I may end up having to do the fix on the valve cover I have read about here. Next on the hitlist is the damn exhaust manifold it was leaking when I got the truck and has steadily become louder. And I will be looking for a new rear bumper since this one is dented up bad on one side and is also pretty well rusted out from the inside, probably going to order the Nates 4x4 bumper.
