shipp_m
Everything posted by shipp_m
  1. sorry there have been no updates on the build. started the police academy and the trailer is in storage until i can find a place to work on it. i do plan on buying parts and stocking up so i can get alot done once i find a garage. from yellaheaps suggestion i am swapping the axle out to a trailer axle and adding in a sway bar. any suggestions on what trailer axle i should use? i believe the axle is 58.5" thanks ahead of time.
  2. It came today in the mail Thanks brock great doing business with you. defenitly will be sending people your way.
  3. Pm sent. Thanks
  4. well looks like i am still looking for the original post then. thanks JohnnyC
  5. just go the ring and pinions and carriers thanks Cruiser. :thumbsup: Just gotta clean all the broken styrofoam out of everything now. lol other than that they look good! :cheers:
  6. this truck looks great! any updates? and what mod is that with the air filter. i have never seen that before
  7. Bump. any body have one?
  8. :cheers: Thanks Hornbrod and yes he is. has helped me with a few of my endevours. :hijack: Any one with an Mj Cargo Lamp Switch Plate i am looking. i have switches just need the plate with symbols. Thanks
  9. well i wasnt sure if you were just saying you had one and planned on keeping it lol. pretty much everything i have for the comanche is in idaho....I'm in texas. what are you looking for? i may have it and my folks could send it your way.
  10. Hornbrod if you already recieved yours you mind if i hijack your thread? thanks Matt
  11. Would you be willing to part with it?
  12. I am looking for a cigarette delete plate for my 88mj. shipping would be to 76084 thanks Matt Pic Stolen from JohnnyC's Build
  13. Thanks Cruiser54 for the ring and pinions and carriers. :cheers: JeepcoMJ thanks for the offer. So all i will have to do is cut exactly 1" out of the drive shaft? or is there a specific amound needed.
  14. JeepCoMj-PM sent
  15. Hi all I'm Matt from Northern Idaho Currently living in TX but my MJ lives in Idaho Still 88 Sportruck I6 4.0 5spd Manual 3.5 rough country add a leaf and 31" tires everyone meet M88J
  16. Cruiser- Pm Sent. thans JeepcoMJ- so i have a swb mj do i still need to cut the rear DS even with a lift? thanks Thanks all :cheers:
  17. Thank you all for your replies and input. My MJ is a 4.0 I6 5speed manual will this effect what i should decide on? so the concensious is that 4:10s or 4:56 will work. if i decide to do light offroading pulling my trailer would 4:56 be the better option? I'm kinda of confused on the carrier? if i use thick gears i won't need a new one or will i need one regardless. Rear= new ring and pinion at 4:56 Thick, a rebuild kit (is this the same as the Master install kit?) and additive (is there a specific kind?) Front= New Carrier, New ring and pinion, rebuild kit and lube is there a specific brand you would all recomend for the parts? Incommando- i appreciate the indepth an response this, i am new to the area and will be looking for a club who might beable to help me out with the rebuild. as far as the perches and springs the axles are MJ specific so i should not need to redo anything to them correct. again thank you everyone for you responses and input with what you are running and how they work/ didnt work for you.
  18. So i have got my hands on a front and rear axle combo for free a little while ago when i bought a cherokee. the seller was moving and said that i could have the axle combo for free and that it came out of a comanche. it is a D44 rear and i found a tag that said use limited slip diff lube only. guesing that it is LSD? found another marking with 3:54 guesing that is the gearing ratio and then a 46-13 i am not sure what this means?? So here's the questions 1) i plan to run a 4.5in lift with 32x10.50R15 tires should i regear to 4:56? 2) If i regear what parts would i need? 3) is this something i could do myself with only basic mech knowledge? 4) Is limited slip good? Thank you for all your help in advance and if i have to broad of questions i am sorry and if needed let me know what info you need. Matt
  19. shipp_m
    Tail Lights
    no problem PeeJ. glad i could help. hope they turn out good for yall.
  20. jensen you don't happen to have a build thread for your cheromanche do you? my brother has an XJ and he wants to do that to it. thanks
  21. excellent thanks Kkilmer87. email sent
  22. As the title states. i am looking for both a short and long spare tire carrier assembly. one is for my truck and the other one is for my trailer i am building. Thank you for your time. Matt
  23. shipp_m
    Flatbed Mj?
  24. shipp_m
    Tail Lights
    http://comancheclub.com/topic/31509-tail-light-restoration/ instead of buying a set wich if you did would be hard to find any cleaner than this. try restoring them. they look brand new. rockrod did a great job. Or http://comancheclub.com/topic/37848-renewing-tail-lights/ these look great too. not that buying another set is a bad thing. just thought this might save you some money.
  25. Sweet thanks.
