Everything posted by MiNi Beast
supercharging__ is it worth it?
MiNi Beast replied to 89sportruck's topic in MJ Tech: Modification and Repairs
renix block is the same so bore it out, intake is different so swap it out, always can cam it, new headers, new head, just need to do some research but you can do anything if you want to. A few links but check out the links thread for a lot of info and products... http://rustysoffroad.com/mm5/merchant.m ... de=PER_AIR http://www.rockcrawler.com/techreports/ ... /index.asp http://www.speedomotive.com/ps-147-15-j ... k-kit.aspx http://www.greatlakes4x4.com/showthread.php?t=661 -
right now I wish for global warming. Just got like 10''+ of snow last night and still more on it's way. Damn I hate 2wd jeeps. :fs1: No Just wish for things to come together for my family moving to AL and making a new life away from the in laws.. :yes:
:clapping:
Axle info for max tire size!
MiNi Beast replied to MiNi Beast's topic in MJ Tech: DIY Projects and Write-Ups
Told by Superior to run the full spool have to use the CCE. SO why not only like $650 for everything so might as well. -
How do you expect to see 75HP from a cam? Maybe 7.5. Roller rockers are worth maybe 2 at most, if that... E-fan, like 6HP? A HO head is worth something, but not a lot... Might as well do the late style intake as well. But still... Bored TB should be worth 1 or 2, add a performance header and see another 5 or 6 at that point. It's not like building a LS1 or a modular Furd. Just giving a rough estimate on the claims of each thing, needless to say my point was you can get alot out of a 4.0 without having to put out a check for 4 grand on a blower. -
I figured eariler on a full spool 4.88 and alloy shaft with c-clip elimanators for the 8.8 and figure a 44 with lockouts for the front and upgrade as well the shafts and for my wheeling style should get a few good seasons out of them. Then if need bigger to to go to a real frame. Or hey you know I could win the lottery. :fool: Well have to play first I guess :doh: -
http://www.4xshaft.com/NP231SHORTSHAFTF ... EKITv2.pdf
well could rebuild it and bore it out. Blue print or balance the engine Or you could just put a cam in it and get like 75hp from that. Rollor Rockers to free up some hp. 62mm throttle body, electric fan conversion, new head. Stage I or II chips. Many ways to had hp and staying under that price of the supercharger. What are you looking to gain? -
I know according to what I bee reading the 8.8 is good up to 40's. So I can keep the 8.8 and run my 37's. Just need to up the 30 to a 44 now. Anyone? -
A list of links for info
MiNi Beast replied to Rokhound's topic in MJ Tech: DIY Projects and Write-Ups
http://www.stu-offroad.com/siteindex.asp and another one with good mod write ups -
Found this over at Pirate 4x4 and thought it would be nice for this site. http://www.pirate4x4.com/forum/showthre ... dana+60+xj or here I posted this one before... http://www.therangerstation.com/tech_li ... guide.html Good axle info from pirate 4x4... FRONT AXLES D27 Front Axle: Full Floating Vehicles: '66-'71 CJ-5 and CJ-6; '63-'70 Wagoneer; '67-'71 C-101 Jeepster Ring Gear: 7.2" Stock Gearing: Axleshaft Spline: 10 Axleshaft Diameter: 1.13" Axle Joint: Spicer 260X Knuckle: Closed Brakes: Drum 10" 11" Weakness: Weak axle for upgrades, low spline count, weak carrier Width: 51" (CJ and Jeepster), 57.5" (Wagoneer) Wheel Bolt: 5x5.5" Max Recommended Tire Size: 31" D30 Front Axle: Full/Semi Floating Vehicles: From ’72 CJ-5, CJ-6, CJ-7, CJ-8, YJ, TJ, XJ, ZJ, C104, WJ Ring Gear: 7.125”, 7.33” (TJ/WJ Only) Stock Gearing: 3.07, 3.54 (3.55), 3.73, 4.10 (4.11) Axleshaft Spline: 27 Axleshaft Diameter: 1.16”, 1.193” (TJ/WJ Only) Axle Joint: Spicer 260X (pre ’95.5), Spicer 297/760X (post ’95.5), CV & 760 U-Joint (TJ/WJ) Knuckle: Open Brakes: Drum 11” (pre ’76), Disc (post ’76) Weakness: 260X U-joint; YJ Vacuum motor fails; standard CV problems Width: 51” (’72-’75 CJ, C-104), 53” (’76-’81 CJ), 56” (’82-’86 CJ), 60.5” (TJ, YJ, XJ, WJ) Wheel Bolt: 5x5.5” (CJ/C-104), 5x4.5” (others) Max Recommended Tire Size: 35” AAM 790 Front Axle Semi Floating Vehicles: '05 and later WK Ring Gear: 7.87" Stock Gearing: Axleshaft Spline: Axleshaft Diameter: Axleshaft Joint: CV Knuckle: Open Brakes: Disc Weakness: Limited modification ability, small ring gear Width: Wheel Bolt: Max Recommended Tire Size: 32" D44 Front Axle: Full/Semi Floating Vehicles: ’57-’65 FC-170; ’63-’70 Gladiator; '67-'79 1/2 & 3/4 Ton Ford Pickups; ’71-’87 J-Series; ’71-’91 Wagoneer; '72-'93 1/2 & 3/4 Ton Dodge Pickups; '73-'79 1/2 & 3/4 Ton Chevy Pickups; ’74-’83 Cherokee; ’03-’06 Rubicon Ring Gear: 8.5” Stock Gearing: Many Axleshaft Spline: 19 (pre ’71), 30 (post ’71) Axleshaft Diameter: 1.25” (19 spline), 1.31” (30 spline) Axle Joint: Spicer 206X (pre ’73), Spicer 297/760C (post ’73) Knuckle: Closed (pre ’73), Open (post ’73) Brakes: Drum 11” (pre ’73), Disc (post ’73) Weakness: 260X and 19 spline axleshafts Width: 63” (FC-170), 57.5” (’71-’73 Wagoneer), 59” (’74 and later Wagoneer), 65.5” (J-Series), 60.5” (Rubicon), Full Width (Ford, Dodge, Chevy) Wheel Bolt: (Varies) Max Recommended Tire Size: 37” D60 Front Axle: Full Floating Vehicles: ‘67-’69 Kaiser M-715; ‘72-‘93 3/4 & 1 Ton Dodge Pickups; ‘74-‘77 3/4 Ton Ford Pickups; ‘77-‘87 3/4 & 1 Ton Chevy Pickups; ‘78-‘79 1 Ton Ford Pickups Ring Gear: 9.75” Stock Gearing: 4.10, 4.56 Axleshaft Spline: 30 Axleshaft Diameter: 1.31” Axle Joint: Unknown Spicer Knuckle: Closed Brakes: Drum 13” Weakness: Metallurgically axleshafts inferior to modern metals Width: 72.5” (M-715), Full Width (Ford, Dodge and Chevy) Wheel Bolt: 6x8.25” Max Recommended Tire Size: 42” REAR AXLES D35 Rear Axle: Semi-floating (’85-’89), C-clip (’90 and later) Vehicles: Most XJ; YJ; TJ (except Rubicon); ZJ; some WJ Ring Gear: 7.562” Stock Gearing: 3.07, 3.54 (3.55), 3.73, 4.10 (4.11) Axleshaft Spline: 27 Axleshaft Diameter: 1.13” Brakes: Drum 11”; Disc (later ZJ/WJ) Weakness: Weak carrier & axleshafts Width: 60.5” Wheel Bolt: 5x4.5” Max Recommended Tire Size: 33” D44 Rear Axle: Semi Floating Vehicles (here we go…*long breath*): ’49-’65 6cyl Willy Wagons; ’49.5-’53 CJ-3A; ’53-’68 CJ-3B; ’50-’52 M-38; ’52-’57 M-38A1; ’53-’57 M-170; ’55-’75 CJ-5 & CJ-6; ’85.5-’86 CJ-7; ’58-’65 FC-150; ’57-’65 FC-170; ’63-’70 Wagoneer & Gladiator Pickup; ’67-’71 C-101 Jeepster; ’72-’73 C-104; ’71-’75 Wagoneer & ½-ton J-Series; ’74-’83 Cherokee; ’87-’91 Grand Wagoneer; Some ’86-’92 XJ and MJ; Some ’97-’06 TJ; ’99-’04 WJ; ’96-’98 ZJ Ring Gear: 8.5”, 8.9” (WJ only ) Stock Gearing: Many, including 3.55, 3.73, 4.11 Axleshaft Spline: 10 (’49-’55), 19 (’56-’70.5), 30 (’70.5 and later) Axleshaft Diameter: 1.193” (WJ/ZJ) 1.25” (10 and 19 Spline), 1.31 (30 Spline) Brakes: Drum 9”, 10”, 11”; Disc (Rubicon, ZJ, WJ) Weakness: 10 & 19 Spline, Some aluminum housings. Width: 50.5” (up to ’75 CJ, FC, C-101, C-104), 54.5” (’85-’86 CJ), 57.5” (’63-’73 Wagoneer), 60.5” (XJ, MJ, TJ, ZJ, WJ), 65.5” (FSJ Cherokee, J-Series) Wheel Bolt: Varies Max Recommended Tire Size: 38" D53 Rear Axle: Semi Floating Vehicles: '55-'65 Willys pickup; '63-'69 Gladiator; '57-'65 FC-170 Ring Gear: 9.25" Stock Gearing: Axleshaft Spline: 20 Axleshaft Diameter: 1.31" Brakes: Drum 11" Weakness: Hard to find parts, low spline Width: 65.5" (Gladitaor), 63" (Others) Wheel Bolt: 5x5.5" Max Recommended Tire Size: 35" D60 Rear Axle: Semi/Full Floating Vehicles: ‘67-‘69 1/2 & 3/4 Ton Ford Pickups; ’69-’87 J-2000/J-20; ‘72-‘93 3/4 Ton Dodge Pickups Ring Gear: 9.75” Stock Gearing 4.10, 4.56 Axleshaft Spline: 30 Axleshaft Diameter: 1.31” Brakes: Drum 12” Weakness: Width: 65.5” (J-2000/J-20), Full Width (Ford, Dodge & Chevy) Wheel Bolt: 8x6.5” Max Recommended Tire Size: 42” D70 Rear Axle: Full Floating Vehicles:’58-’68 FC-170 w/dual rear wheels; ’63-’68 J-3000 w/dual rear wheels; ’67-’69 M-715; CJ-10; '72-‘93 3/4 & 1 Ton Dodge Pickups; ‘76-‘77 3/4 Ton Ford Pickups; ‘77-‘87 1 Ton Chevrolet Pickups; ‘78-‘79 1 Ton Ford Pickups Ring Gear: 10.5” Stock Gearing: 4.10, 4.56 Axleshaft Spline: 23, 35 Axleshaft Diameter: 1.5” Brakes: Drum 13” Weakness: Poor parts availability Width: 59” (FC & Pickup), 72” (M-715), Full Width (Ford, Dodge and Chevy) Wheel Bolt: 6x7.25” (M-715), 8x6.5” (others) Max Recommended Tire Size: 44” AMC20 Rear Axle: Semi Floating Vehicles: ’76-’86 CJ; ’76-’91 Wagoneer and J-10 Ring Gear: 8.875” Stock Gearing: 2.76, 3.07 Axleshaft Spline: 20 Axleshaft Diameter: 1.31” Brakes: Drum 11” Weakness: 2 piece axleshafts (CJ only), tubes spin, 20 spline Width: 50.5” (’76-’81 CJ), 54.5” (’82-’86 CJ), 59” (Wagoneer), 65.5” (J-Series) Wheel Bolt: 5x5.5” (CJ), 6x5.5” (Wagoneer and J-Series) Max Recommended Tire Size: 33”-35” Chrysler 8.25 Rear Axle: C-clip Vehicles: '91-'01 XJ Ring Gear: 8.25” Stock Gearing: 3.55, 3.73, 4.10 Axleshaft Spline: 27 ('91-'96), 29 ('96-'01) Axleshaft Diameter: 1.17” (27 spline), 1.21 (29 spline) Brakes: Drum 11” Weakness: 27 spline, c-clip Width: 60.5” Wheel Bolt: 5x4.5” Max Recommended Tire Size: 35” Ford 8.8 Rear Axle C-clip Vehicles: Ford Explorer (Prefered Swap, information reflects Explorer only), Ford F-Series , Ford Ranger Ring Gear: 8.8" Stock Gearing: 3.08, 3.27, 3.55, 3.73, 4.10 Axleshaft Spline: 28, 31 Axleshaft Diameter: 1.320" Brakes: Drum ('91-'94), Disc ('95-'01) Weakness: C-clip, weak carrier Width: 59.625" to 65.6" Wheel Bolt: Most 5x4.5" Max Recommended Tire Size: 40" Ford 9 inch vehicles: 57-'59 Ford station wagons, including Ranchero and sedan delivery 58-'90 F-100 and F-150 pickups 57-'67 Thunderbird 63-'69 Falcon and Comet 57-'64 Ford and Mercury full-size cars 63-'69 Fairlane (note: '67 Fairlanes had coil rear springs instead of leaf) 58-'60 Edsel 66-'77 Bronco (uses a larger five-on-51/2-inch wheel bolt pattern) 75-'78 Ford Granada and Mercury Monarch 71-'76 Torino, Ranchero and Mercury Montego 77-'81 Lincoln Versailles 70-'79 Lincoln and Continental 72-'86 E-250 Ford vans 65-'73 Mustang 67-'73 Cougar Stock gearing:2.50,3.08, 3.27, 3.55, 3.73,4.11,4.30 Axleshaft Spline:28, 31 Axleshaft Diameter: Brakes: Width: Wheel Bolt: Max Recommended Tire Size:40" AXLE STRENGHTS: COT - Continuous Output Torque MOT - Maximum Output Torque Dana 35 ........................ COT: 870 MOT: 3480 AMC 20 ......................... Chrysler 8.25 ................. Dana 53 ........................ Dana 44 ........................ COT: 1100 MOT: 4460 Ford 8.8 28 spline ........... COT: 1250 MOT: 4600 Ford 8.8 31 spline ........... COT: 1360 MOT: 5100 Dana 60 semifloat ........... COT: 1500 MOT: 5500 Dana 70 ........................ Rockwell 2.5 Ton ............ IDENTIFICATION: Tag Identification: D30: “30” cast into back of diff casing on top right and left next to diff cover. Tag bolted on diff cover with axle ID and gear ratio. D35: “35” cast into back of diff casing on top right and left next to diff cover. “C” next to “35” DOES NOT stand for c-clip, but “custom” (unfinished by Spicer). Tag bolted on diff cover with axle ID and gear ratio. D44: In most cases “44” into back of diff casing on top right and left next to diff cover. Tag bolted on diff cover with axle ID and gear ratio. D60: Similar looking casing to the D44, except the oil fill plug is elevated to provide more fluid for the larger gears. Chrysler 8.25: Tag wrapped around passenger side tube with axle ID and gear ratio. Ford 8.8: See Joe Dillard and T.Dome's writeup linked at the bottom of the page Differential Cover Identification: AMC 20: 12 cover bolts, round cover, fill plug not present D27: 10 cover bolts, oval with straight sides, distinguished ring gear extension, low fill plug D30: 10 cover bolts (five on top, five on bottom), oval cover w/flat sides, fill plug just below centerline D35: 10 cover bolts, evenly spaced, oval "dome" shaped cover with low fill plug D44: 10 cover bolts, hexagon shaped cover with very round edges, fill plug on centerline D60: 10 cover bolts, hexagon shaped cover, fill plug on centerline D70: 10 cover bolts, hexagon shaped cover, fill plug on centerline Chrystler 8.25: 10 cover bolts, oval shaped cover, fill plug just below centerline Ford 8.8: 10 cover bolts, square with very round edges, fill plug not present on cover Gear Identification: If the gears are unidentifiable from the tag or if the tag is missing, there are two methods to find the gear ratio. 1) Spin the tire one full rotation and watch how far the driveshaft rotates. Double the amount the driveshaft rotated, this gives you your gear ratio. Be sure you are spinning the tire forwards. 2) Count ring & pinion gears: Count the number of teeth on the ring and the pinion. Then divide the ring teeth by the pinion teeth to attain the gear ratio. And thanks to: Travis Waldher Pirate4x4 Addict! for some changes. 1) The AMC20 that came under the CJ is a different animal from the one that came under the waggie. A waggies pumpkin webbing is different, tubes are plug welded in to the housing, 29 spline. I think 2.21 was also a gear option -- I think. One perc to at least the waggie version is the massive pinion - the shaft is the same diameter as a D60.
:hmm: may have a over heating issue with that there kink in the hose, may need to adjust that some.
A few XJ to MJ inquiries
MiNi Beast replied to The_Slow_Norris's topic in MJ Tech: Modification and Repairs
coils are most likely Skyjacker. you maybe have like a 3in lift with 31's. We all mostly are cold right now weather is goofy period, but good luck with your build and stay around we all like pics and love to help and give opinions, (especially jtdesigns, gotta watch him :rotf: ) -
C'mon man join the chat, got tech question come ask, wanna bs come do that, I';m good at BSing..... :rotfl2: :rotfl2:
Chat room is open anyone?
I ran mine like that for a while, then I ran a YJ yoke and payed no never mine to it untill I lifted it more then just went and got my drive shaft lengthen and it cost around $100 bucks. A new YJ yoke cost around $75, so which ever you want to do and what you have in store for the rig.
Check out Motion Offroad... http://motionoffroad.com/catalog/ Bedsides check out here... viewtopic.php?f=2&t=7519&hilit=+fiberglass+bedsides+ Write up on cooling... viewtopic.php?f=9&t=7695 Sye.. I ran about 5.5" varies really. -
http://www.chatzy.com/356793059116 http://www.chatzy.com/356793059116 http://www.chatzy.com/356793059116
Possible bad axle shaft??
MiNi Beast replied to MiNi Beast's topic in MJ Tech: Modification and Repairs
Just an update for the search button. Well was a stretched chain in the tcase. Pulled the drain plug and seen the chain hitting the case. So took it in to have it rebuilt. Took it to Keith Bailey at Off Road Connection, http://offrdconnection.com/photos.htm and they good good care of me. Had it back the same day. Cost was about $350 including the synthetic fluid that I run in it now. -
