mjeff87
    8
Everything posted by mjeff87
  1. I'll try to get down there after work tonight or tomorrow. It's supposed to snow here on Saturday so I'm not going to be outside much over the weekend. I'll backchannel you and let you know either way. Anything I can do to keep these things on the road, I will. There's also a shortbed MJ down at my junkyard (at least there was last week when I was there). It's pretty hashed all over, but it should still have the filler neck on it. That might be option 2, but I'm not sure when I could get down there to check. You wouldn't happen to be local to me would you? (pro tip, it helps to put your location in your profile for stuff like this). I could point you to the junkyard if you wanted.
  2. I *think* I still have a spare one in my parts pile down in the shed. Give me a day or two to get down there to look, and if I still have it it's yours for the cost of shipping.
  3. mjeff87
    M35A2
    My KJ is only the second vehicle I've ever owned that wasn't a stick. I do enjoy driving it (most of the time, lol) to give my left leg a little holiday.
  4. My buddy, who recently retired as a plant maintenance foreman for a huge chemical plant around here got the tool for me to use from his equipment shop. It was a bear of a thing to use, I do remember that. It wasn't something you could pick up at the local Autismzone or similar. I basically had to use a floor jack to squeeze it. I do like your idea.
  5. See if you can buy/rent/borrow the other style of rivnut tool, the one that looks like a pop rivet gun on steroids. I installed a couple rivnuts in mine to hang a transfercase skid a long time ago, and compressed the handle with a small floor jack. It worked great.
  6. mjeff87
    Gas prices
    Filled up the Focus at the Murphy's (outside the Walmarts) yesterday at $3.75/g for 87. Literally everywhere else is $3.99. The KJ is not coming out to play. edit: wife just texted me and said the Wawa on her way to work is now $4.15.......
  7. mjeff87
    M35A2
    The shift pattern was different on the 2.5T. 4th was up and down from 3rd, then 5th was up. That messed up many an operator. And the 2 speed transfer case was manual but required a transmission downshift to go from low to high, and an upshift from hi back to low. With as heavy, and slow (relatively speaking) as those things are, plus a non synchronized trans, one did not split shift like you do in a more modern heavy vehicle. 4/5 shift is when you split, and on pretty much level ground, lol. Even in 5/high, when you got there, 60-ish mph was about all you ever feared to do unless you had a death wish. Plus the fact that you were pushing that multifuel engine around 3000 rpm. It would do it all day long, but that turbo whine literally pierced your skull inside the cab. That video kinda gives you a sound of the turbo but it doesn't do it the justice it deserves. Mickey mouses, or at least insert earplugs are/were mandatory equipment, if you weren't dumb.
  8. mjeff87
    M35A2
    For those of a certain age and possible prior service. This is one of my favorite saved videos...it brings back alot of great memories for me. I was licensed up to a 10T HEMMT back in the day, and my assigned vehicle was a 5T ancient M543 wrecker with a boom crane on the back. If I ever come up with a spare few thousand $$$$ before I die, I'd love to purchase a surplus 2.5 or 5T and cruise it around my neighborhood.
  9. Bring it brother. You know what the spare bedroom looks like
  10. If anyone wants parts from any of this, let me know. I can/will run back down this weekend. Not dropping a trans though, lol. The MJ is hashed, like I said. I grabbed the fuel pump assembly but there isn't much else to get. Cab vents are gone. Interior is hammered, dummy gauge cluster is about the only thing still there. Both taillights are screwed as is the rear bumper. Rear slider window, but its fukkered as well. 87 model, 2.5L/AX5, 2WD, D35 rear. Has A/C, most of the engine bits seem to be in good shape, FWIW.
  11. I took a sick day from work today, I was having some vision problems this morning. There was no way in heck I could see myself going to work today. Anyhow, I ran to the 'yard to grab an oil fill cap for the KJ to pattern a tool I'm going to make to twist mine off. And I hit junkyard gold. Got a cap and then spied an MJ. It is completely hashed, but I did grab the fuel pump/assembly from it if someone here needs it. There is also a 96 Dakota there with a 2.5/AX15 if anyone is interested in the BH. I'm not going to pull it, but if anyone needs details and wants to come here to get it, I will help. Then I saw an 04 focus wagon that had brandy new front loaded struts and steering knuckle hubs/bearings. All of that came home with me, to be swapped out this weekend.
  12. mjeff87
    Tool Talk
    I've got a couple different cheater pipes, but I picked up another one a couple days ago at work. We had some contractors in working on the sprinkler system and they chucked a cutoff piece of schedule 40 in the trash. Its now in my garage
  13. Just an FYI for anyone that isn't aware, radar detectors are illegal in VA. And VSP has technology to detect your detector, lol. On a brighter note, you can pretty much ignore any "speed enforced from aircraft" signs on VA interstates. VSP has all but abandoned that program long ago......I think they just kept the signs up to act as a deterrent.
  14. mjeff87
    Tool Talk
    That's pretty trick. I didn't invent it per se, but I repurposed something. It originally was a metal "wand" of sorts with interchangeable tips you would screw on and then hook to a garden hose to make a poor man's power washer. It works just as horribly as you would expect it to for that purpose. My mother (RIP) gave it to me a long time ago and I just didn't have the heart to toss it out. So, I expertly re-engineered the wand part (read: bent the crap out of it) and removed the tip(s). I use it to flush heater cores with now and it works great. It's got a quarter turn shutoff valve on it with a handle, and is long and skinny enough to get inside the inlet/outlet pipes on any vehicle I've used it on. If you've ever had to flush a KJ core, you'll know that it's a real PITA to get to the pipes.....this thing makes it really easy. I'll snap a pic of it tonight. ETA pic.
  15. To reset the switch, it needs something ridiculous like 500 lbs of pressure. Try sitting in it (engine off) and mash down the pedal, HARD. It will make a little "click" sound when it resets.
  16. I try to stop about every 2 hours, if noting else just to get out and stretch my legs. It might sound old fashioned, but AM talk radio can be your friend.....something for you to focus your mind on instead of a steady stream of music. I also like to take snacky-type foods and just nibble on them throughout the trip (again, it gives your mind something to do). Salted pumpkin seeds are my favorite. All that being said, I did fall dead asleep on the Ohio turnpike once, for over a solid minute. Woke up and was still driving straight down the highway. If you are familiar with the road and scenery there, you'll know this isn't an impossible thing to do.
  17. mjeff87
    Tool Talk
    I used 12 ton stands (ratcheting, with safety pins) as well. Bigger beef, wider, more stable, and gives you plenty of room to work under. Good stuff.
  18. mjeff87
    Tool Talk
    Yeah, no glare like Frank says. I wear glasses (when I want to see things) but not when I'm working on stuff. I'm near-sighted. But I do wear safety glasses and this thing doesn't cause any issues for me. Its like a floodlight that lights up the entire working area evenly. I do have a point-light harness also to focus light to a specific area when needed, but it won't see much gametime now that I have this thing.
  19. mjeff87
    Tool Talk
    Dragging an old thread back to life, lol. I totally forgot to follow up on this. I did pick one of these up a couple months ago, and it is definitely worth the price of admission. I've used it in the garage a few times already, and used it a couple weeks ago (when I had a covid vacation from work for a couple of weeks) to install a new kitchen sink faucet. It works great underneath the sink to fiddle around with the supply lines and fastening devices. I'd highly recommend them. They make three different models (good, better, best...ish), I sprung for the middle ground one, which is PLENTY bright enough for the stuff I do. If I had only one tiny criticism about it, that would be the clunky battery box on the backside of the headband (they use 2-AAA batteries, not included). It's completely functional, but I think they could have integrated the battery area(s) into the headband a little "cleaner" than that box. It's more an aesthetic thing than anything to me, I guess. Maybe the 2.0 versions they'll eventually come out with will be different. Still wouldn't stop me from buying one again, or recommending one to anyone.
  20. Nail on the head Pete. Ive got a swapped in junkyard knuckle on the focus right now thats not drilled for the ABS sensor. Got the old one sitting in the shed waiting on a new wheel bearing, which ill get to before June when the sticker expires. I'm absolutely fine with that.
  21. Interesting.....I'll have to try the blinker thing to see if that changes things. Thanks.
  22. Add me to the HATE crowd. I love driving my wife's Subbie, but absolutely cannot stand all the nanny controls. Adaptive cruise is annoying to me, for all the reasons previously stated. It's even starting to bug her a bit too. It can be turned off, along with the lane departure warning alert, and the auto-shutoff at stoplight thing. Which I do every time I drive her car. But you have to disable/turn them off every time you stop/start the vehicle. The crash warning/automatic braking has it's place, I'll give it that. BUT, when you're on a 2 lane road with limited passing zones, and you see a zone approaching you can't speed up behind the (slowly moving) vehicle in front of you to time out entering the passing zone to swing out, pass, and get your butt back in the lane. It actually engages the brakes (and makes all kinds of scary alarm sounds). I am the farthest thing from an aggressive driver (my wife actually calls me Ms. Daisy.....), but when I drive I like to keep momentum and all my moves as fluid as possible. I am constantly judging traffic patterns and using my rear view mirror to anticipate gaps in traffic so I can move between lanes and maintain my speed. All the new safety stuff makes that pretty difficult. It doesn't fit well with my driving style, but I can see the benefits for other drivers. It all would have been a godsend for my mother when she was still alive and driving.
  23. It's a Jeep thing.....you wouldn't understand......
