88manche4x4
Everything posted by 88manche4x4
I'm puttin honda prelude bucket seats in mine.
Idiot Guages - got to replace
88manche4x4 replied to hogelectra's topic in MJ Tech: Modification and Repairs
So I got a challange for ya. Colum shift MJ, All idiot lights. ????what now????? -
Thanks! I brought the fail with me.
Ok i failed. How did you guys get it to post?
Pretty much. I've had people in stock AND lifted XJ's have to take a double, even triple take when i drive by. People have actually stopped me and asked me if i cut up an XJ and did this. They were amaxed that jeep made a pickup on the XJ platform. I just thing a waggy fascia would be even more fun. Plus you don't see them every day.
How many people have MJ's with XJ waggy facias on them? I really want to do it to mine, just to confuse the living daylights out of people. I know its a direct swap. :banana:
what engine do i have?
88manche4x4 replied to 69CamaroSS's topic in MJ Tech: Modification and Repairs
Well CC is usually european... 4.0i 3956cc [A40MPI] - 4.0, multi port fuel injection - euro 4.0i 3956cc [C40MPI] - 4.0 multi port fuel injection - euro 4.0i 3956cc [L400L] - pretty sure carb's - euro 4.0i 3956cc [M400L] - pretty sure carb'd - euro This is what you have. 4.0L 242cid L6 MFI (M) -
Well as promised, here are some painted pics. I decided to get rid of the metal piece that stock up infront of the tailgate. Somethings gonna go there eventually. It really doesn't stick out THAT far. I made it so that the sides that wrap around stick out about even with the stock flares. It hangs down about an inch or less below the body. I tried to tuck it up as far as I could.
Well, I decided that I didn't like my old flimsy stock bumper, and I had an old bumper from a hot rod project. I got a welder for Christmas and I was bored, so things clicked. here's my build. here's the bumper. Outside width is 74'' wide, about 10'' wider than the stock MJ bumper. Most of that was the extra metal. The bumper brackets needed to be cut out and replaced. I needed to cut down the bumper a total of 5'' (2.5'' each side) to make it fit. It is made out of 1/8’’ and 3/8’’ plate steel. THIS WILL NOT BE A LOAD BEARING BUMPER. That is what ii have a trailer hitch for. Nothing will ever be connected to it. Pictures of brackets Test fits Start to cut. I didn’t think about where I was cutting so I cut a little further in than I wanted. I guess I should have measured. Oh well. here's one side cut. I didn’t take pictures of the other side cut. I took 2.5 inches out of each side. One side tacked back on. This shows how far the bumper sits below the bed. This shows the side where it will be bolted to the bed. I will use a rubber bushing on each side of the bed and a washer between it and the nut on the inside of the bed. Other side tacked on. I have a little bit of a gap in between where I cut. My sawzall skills are lacking. I’m using the metal that I cut out of the bumper for form “straps” over the gaps, then welding that on the outside and inside. That’s my rear bumper build, Hope ya’ll liked reading it. I also cut my front bumper at an angle like just about everyone else. here's pics. :ack:
Damnit! and I can't go.
I have no clue what sixe X's your running, but I'm running 33x12.50 and REALLY have to watch it in the wet stuff. The lightest touch of the gas sends the back end out.
I need someone with a longbed MJ with a 4.0L/aw4/242 to measure their rear driveshaft from u-joint to u-joint. I want to get a driveshaft made while I'm doing the 2wd to 4wd conversion so I can drive it right away.
Start digging. Dis trails for the rear tires to follow, that will make it MUCH easyer to get it unstuck. I have to ask, where did he think he was going with that?
It appears that it runs off the dewalt battery. It has something that says dewalt on the gun.
I'm right at home in Portland, Oregon. If you have time and wanna get out and wheel that mutha, Come on over to NAXJA. org to the NWC. We go on lots of wheelin trips (1-4 monthly). My name over there is 85xj4dr, mainly because theres a 1985 XJ 4door sitting in my back yard (FOR SALE!!). here's the link: http://www.naxja.org/forum/forumdisplay.php?f=66 I drive a 1988 Burgandy MJ. If ya see me, Give a wave or a holler! I usually wave to other built Xj/MJ drivers. here's a pic of my rig.
What is the front axle thats in the one your getting for free?
I need some measurements..
88manche4x4 replied to 88manche4x4's topic in MJ Tech: Modification and Repairs
Can someone with a Longbed with a 4.0/aw4/231 PLEASE measure they're rear driveshaft from u-joint to u-joint? Bonus points if i can get measurements for a 4.0/aw4/242 in a longbed MJ. -
Get it. Axles are cheap. Don't buy the one from the other guy, though. Is not worth it unless the body is spactacular and has no rust, or theres something special about it. A 360 is a de-stroked 390. Pull the engine and put in a 390 crank and rods, you now have a 390. TDC on 360's is below deck height. The 360 is still a great engine though. I had one in a '68 F250 that I restored.
Your neighbors are lucky. I have a 1993 Ford F250, 1984 F150, 1971 F100 Project, my 1985 Xj, my 1988 Mj, 1997 Chrysler LHS, a 18' starcraft, a 21' starcraft project, a camper, and a 1941 International KB-8 2.5 ton flatbed.
Thanks. That means i have about 5'' of lift on mine. no wonder i rub with 33's. Also, how long should i make my rear driveshaft, ujoint to ujoint with my SYE at half slip? I measured my trans thats in there and my 4wd setup thats on the floor, and its 4'' longer. that means i would make the driveshaft right about 32'' - 33'', right? BTW its an 88 Longbed -
Differences in MJ and XJ headlights?
88manche4x4 replied to ComancheKid45's topic in MJ Tech: Modification and Repairs
Some states Don't like them. Just make sure you either get ones that say 50 state DOT approved or you live in the listed states they're approved for. Most cops probably won't care though. -
If anyone has the stock hub-to-flare measurements for and 88 comanche 2wd, could you post them? My friend thinks I have 7.5'' of lift on my 'manche but i think its closer to five.
