Everything posted by Wrz
WRZ's comanche Now the 96 od2 swap in progress
Wrz replied to Wrz's topic in Member Projects: Your Comanches
This is the farthest I've ever gone into a motor, how hard is it to change the timing chain? And good write up or a good brand I should go with? Thanks -
Damn its been over a month since i last updated my build, Sadly not much progress has been made, but have ordered alot of parts for her. Havent been able to work on the comanche due to the weather and having a tenant living above the garage lol Curently working on a few projects at the girls house Picked up a later xj dana 30 from a 99 All the unwanted/garbage parts in a pile Started to grind down the passenger side Will hopefully finish grinding her down tomarrow, then a fresh coat of paint and the upgrades and installs come stay tuned :popcorn: Previous toal- $2006.20 Dana 30 axle - work perk :) New total - $2006.20 -
The pacesetter headers are on and fit good, haven't had any luck with an egr tube, I tried to bend the original one and cracked it, think I might bend one out of copper Motors still on the stand so cannot say ow the headers sound yet -
I work at a jy so I always get the jy prices which are usually a lot cheaper, I'm going to give them a call tomarrow and see ow much they want for everything Will keep posted
Thanks for the response, I've been searching for awhile for some info. I'm going to order them tomarrow and post my results when I get them Thanks
Anyone know the interchange for the seatbelts? I'm in the process of redoing my interior and found a good deal on a set of 1986 black ones. My trucks a 1990 Thanks and any info or tips would be appreciated
Digging the yellow and the super bee logos
$250 For A Chrome Handle
Wrz replied to Alexia's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Damn I didn't even get to put mine in as it jumped a lot within the last 10 seconds -
Have little over a foot over here on Long Island (Suffolk) will post some pics in the am ;)
It's coming along good, what brand undercoating did you decide to use on the frame?
Hey I bought the set off eBay for $100, they have really good reviews Here's the link and ask him for a jeep forum discount http://www.ebay.com/itm/Upgrade-1987-1990-Jeep-Wagoneer-4-0L-Fuel-Injectors-/281060592437?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AJeep&hash=item4170844b35&_uhb=1 -
Engine is pretty much done for now, Just need an egr, cap & rotor, and an egr tube. Started to prep the engine bay for paint, Would have been easier if i knew how to disconnect all the harness that go into the firewall Think i might need some new motor mounts, what do you think lol And some more engine bay pics Weather permitting next weekend i will start to paint the engine bay, and monstaline the frame and under carriage Stay tuned :popcorn: -
Knocked a few things off the to-do list, with lots of pics http://comancheclub.com/public/style_emoticons/#EMO_DIR#/smile.png Picture of the new oil sensor installed Removed the oil pan for a cleaning and new gasket Before After Installed halfway ( have 3 broken bolts in the block, 2 from the po and one from me, still need to figure out a way to fix it ) Got my new 140amp alternator, Bought off ebay for $118 shipped, direct bolt in with no mods needs And Installed Fuel rail before Wire wheel does wonders, All polished up and ready to be installed New upgraded fuel injectors, bought off ebay for $110 Swapped and upgraded sensor fo gauge swap Installed Hit the valve cover with another coat of paint, Later model valve cover gasket Upgraded the engine block ground with a taylor one, little bit of over kill but it works for me And everything installed Man can't wait to finish the drivetrain and get everything all bolted in so i can start on the body and axles Waiting for my torque converter to get back from the shop, Seals are all done but apparently my converter was shot Previous total- $1691.25 Oil sensor- $15.99 Oil pan gasket- $20.99 Alternator- $118 Injectors - $110 Temperature sensor- $15.59 Valve cover gasket- $26.39 Taylor engine ground $7.99 Cost to date- $2006.20 -
Working on bending the pipe to fit my headers, or use some hight heat hose as a last resort. I'm looking for the valve Thought about eliminating it completely but have read that the motor will run like crap without it Yeah I can get an inspection with or without it
Currently redoing my motor and my egr is shot, looking for a new one Pm if you have one for sale,
Nice platform to start with, any idea what those seats came out of?
Thanks it's coming along, not as quick as a prefer but should look good when all done :) -
Had another good weekend on the comanche and made some more progress on the engine Pulled some accessories off the front Did not take too many before pictures, but here are some of the almost finished product New Waterpump and painted pullys Upgraded the fan clutch with one from a 98 ZJ and painted the fan New high flow thermostate housing and 180 degree stat Cleaned and painted the a/c compressor and brackets Picked up a new to me valve cover from work, Nice upgrade Upgraded the oil temperature sensor for when i do the gauge cluster swap Front assembled Changed the plugs and wires and they sent me the wrong cap and rotor http://comancheclub.com/public/style_emoticons/#EMO_DIR#/fist shake 1.gif Not too bad for a few hours of work Still need to swap injectors Add a second coat of paint to the valve cover and install Wait for the brown santa to bring me alternator Order a new cap and rotor Change oil pan gasket and paint/clean decide what to do with my throttle body ( really want to add the h.o one ) Swap in water temp sensor for futue gauge swap I know I'm forgetting a few other items on the to-do list If theres anything else i should swap out or upgrade feel free to chime in Previous total - $1512.50 Water Pump- $30.00 High Flow Thermostat $50.85 Zj Fan Clutch- $44.95 Autolite Plugs- $9.00 Taylor wires - $43.95 Valve Cover- Work Perk Cost to date - $1691.25 -
I hear ya deffently a gamble, but the owner i bought it from was pretty on the money as far as what was wrong with the jeep, so i have my fingers crossed -
Starting to clean up the motor one side at a time, Got the intake and exhaust manifold pulled ( to my suprise all the bolts came out very easy ) Knew the exhaust manifold was cracked and prevously welded a few times Time for an upgrade, picked up some pacesetter headers off ebay a few months back for $147.50 shipped Quick coat of paint since they had some paint chips from being moved around. ( also painted the motor mount ) Cleaned and painted the intake manifold and heat shield Block after a cleaning and some paint Throttle cable bracket cleaned and painted as well Painted the bolts and will have to swap the washers with the new ones that came with the headers ( forgot all about them till i called it a day ) Shinned up the brass fittings with a wire wheel Exhaust mocked up Image Not Found All assembled Image Not Found Image Not Found Hopefully i can find a good egr tomarrow from the jy, Apparently the egr tube needs to be modified to fit the headers, its off by a solid 5/8 and need to get the one bolt in behind tube 4. Think i will try to grind it down some Previous total - $1365 Headers $147.50 Cost to date- $1512.50 -
Thanks I've been debating on doing a floor shift swap, but kind of like the old school column shift lol -
Been awhile since ive updated my build, Stripped the front end of its sheet metal 2 weeks ago, and Finally made some real progress last weekend and got the engine pulled, figured it would be easier to replace the exhaust manifold, motor mounts ect and paint the engine bay with the engine out the way. First time pulling a motor and it went fairly good with a few broken items but nothing too major Gave the engine a quick bath and who would have knew my block is blue lol Been a little nervous putting all this time and money into this engine that i never head run since the trans was in the bed when i bought it. Takes a small edge off of things knowing it was rebuild at sometime And the engine bay after a pressure wash Tomarrow i will start on replacing gaskets and some engine goodies :) more pictures to come tomarrow
