Twisty Posted June 21, 2007 Posted June 21, 2007 well I turned mine into a corkscrew tonight. Is it better to get another stock one, or should I spring for an after market piece? I don't really want to go through this again. Are shafts like Tom Woods stronger? Is it worth it to eliminate the slip yoke, and go with a SYE? I have no vibs, so I don't really need it. Thoughts?
DirtyComanche Posted June 21, 2007 Posted June 21, 2007 Wheel it? Hard? A HD SYE is a strength upgrade, worth it if you abuse it. And TW, JE Reel, High Angle, etc all build some pretty stout shafts if you want them to.
pingpong Posted June 21, 2007 Posted June 21, 2007 The SYE is definately a strength thing.... also a pice of mind thng that the slip yoke won't come out from over flexing. As far as the driveshafts go... if you don't get a SYE go to the JY and get some used shafts. If you go with any of the big makers.. buy their trail insurance if they offer it.. I had a TW one built for Pong, and needless to say over time it had been flat spotted and had some candy cane marks on it.. didnt buy the insurance.. had to have it re-tubed locally, which only cost a lil over 100 bucks
Pete M Posted June 21, 2007 Posted June 21, 2007 What? No story? I wanna know how you did it! And where are the pictures?! :brows:
DirtyComanche Posted June 21, 2007 Posted June 21, 2007 I killed a TW myself. Pulled the slip shaft on it at full throttle. As the driveshaft centrifuged out it broke/flattened every yoke, crushed every u-joint, and twisted off a bunch of the splines. I didn't know he sold any extended warantee. I don't think it would have covered that anyways. A learning experience - buy a long travel shaft if you're getting it built from scratch anyways.
Twisty Posted June 21, 2007 Author Posted June 21, 2007 What? No story? I wanna know how you did it! And where are the pictures?! :brows: Its quite boring actually. I was playing on my neighbor's rock pile, and got hung up on a rock, and a telephone pole that was laying there. A rock was under the left rocker pannel, and the right front tire was off the ground. I had no traction. I pulled the truck back with my XJ, and had somone give it some gas. It began to corkscrew, and pulled out of the slip yoke. Pic: I think I'm going to try to get it re-tubed locally. I don't have $500 to spend on an SYE and new DS right now.
XJ Maki Posted June 21, 2007 Posted June 21, 2007 I had my stock shaft retubed after twisting it up. It cost about $125 and they used a heavier wall tube than stock and made it 2" longer to correct for the lift. <-- Mitchell's in Shrewsbury, MA :thumbsup: The MJ doesn't usually need a SYE to address for vibes because of how long the shaft is and also I've driven alot on just the front shaft: 16 oz soda bottle and a hose clamp works flwlessly for that.
Twisty Posted June 21, 2007 Author Posted June 21, 2007 I had Mitchell's in mind. Thanks for posting. I will give them a ring. There is also a place in Leominster that does it I think. I don't really have the $500 for a new shaft and SYE now, so I think that re-tubing the drive shaft with a heavier tube is the best option.
pingpong Posted June 21, 2007 Posted June 21, 2007 Yeah you have to ask about it... a guy in the club had a long travel front on his Scrambler, and the bottom part let go in the splines... and he covered it. I think the warranty is like 50bucks...
feerocknok Posted June 22, 2007 Posted June 22, 2007 That shaft is Nasty! Nice job! Did we all decide that Wrangler slip yokes have the same travel in them? They can just operate at more extreme angles because of the ear design?
DirtyComanche Posted June 22, 2007 Posted June 22, 2007 Did we all decide that Wrangler slip yokes have the same travel in them? They can just operate at more extreme angles because of the ear design? I hope so. Because I've seen the proof.
Pete M Posted June 22, 2007 Posted June 22, 2007 :bowdown: Yeah, that one would definitely be mounted on the garage wall. :D
MrShoeBoy Posted June 24, 2007 Posted June 24, 2007 Get a local shop to build the shaft. Just tell the local shop EXACTLY what vehicle it will be going in and what its intended use will be and they will set you up with a shaft just like the high doller "big name" comanies and you won't have to pay for shipping. AARON
Twisty Posted June 25, 2007 Author Posted June 25, 2007 Get a local shop to build the shaft. Just tell the local shop EXACTLY what vehicle it will be going in and what its intended use will be and they will set you up with a shaft just like the high doller "big name" comanies and you won't have to pay for shipping. AARON Once I get paid...this is the plan!!! Thanks! 8)
