Best way to remove the Jeep letters from in front of hood
You have to remove the brace attached to the radiator support that the header panel bolts to. Your '89 should have nuts that hold the letters in place, at least my '88, '89, and '90 do. In '91 they went to adhesive backed letters and headers without holes in them.
My '89 header used nuts to hold on the emblem. A 1/4 drive flex socket worked well.
My' 94 and '95 XJ headers used double sided tape to hold the emblems on. Some heat from a heat gun and they came right off. Any tape that was left rolled right off with a little more heat. :brows:
:cheers:
