Ben-88Comanche Posted May 3, 2008 Posted May 3, 2008 Hey I don't remember who, but I remember someone who had a cone intake they got at advanced or autozone for like $50, and they had the hose that connects the air intake to the front hole in the valve cover. if anyone knows where to buy this or has it, let me know the info on it. Mine has a breather stuck in there instead and it doesnt fit tight, leaks a little. Again, not looking for an expensive K&N cold air intake, just looking to replace the factory airbox with a cone style one, and having all the nessesary hoses. Thanks
maddzz1 Posted May 3, 2008 Posted May 3, 2008 If you want you can just replace the piece that goes on the front of the valve cover its only $20 at napa: http://www.napaonline.com/masterpages/N ... entilation Or do you mean you want an air tube: http://rustysoffroad.com/mm5/merchant.m ... de=PER_AIR
jpdriver1 Posted May 4, 2008 Posted May 4, 2008 for quite awhile I used an inexspensive cone filter and the flex tube off of a v-8 taurus (had the two emission ports needed for my 90)
Ben-88Comanche Posted May 5, 2008 Author Posted May 5, 2008 Maddz i guess I'm looking for both figure as long as I'm spending money might as well get the upgrade I need the airtube and the hose that connects it to the front of the valve cover. looking at pictures of other XJ's and MJ's I'm realizing I'm missing that whole piece of emissions stuff, on both my 88 and my parts (89). Do you have anything to say positive or negative about the rustys airtube? And does it come wtih the piece that goes to the front of the valve cover? and I'm always lookin around junkyards, if i find a v8 taurus ill check it out
maddzz1 Posted May 5, 2008 Posted May 5, 2008 theres nothing from the airtube that goes to the front of the valve cover. The tube from the TB is the main tube on the air tube. THen the rubber tube that comes off the vacuum line from the purge cannister connects to the side of it and then the rubber tube from the other half of the vacuum assembly that connects to the front of the valve cover connects to the other side of the air tube. If you want to replace all the vacuum lines from the CCV system from the valve cover these are the 3 you need: http://www.napaonline.com/masterpages/N ... entilation http://www.napaonline.com/masterpages/N ... entilation http://www.napaonline.com/masterpages/N ... entilation
Ben-88Comanche Posted May 6, 2008 Author Posted May 6, 2008 so those 3 tubes magically fit together all neat and such? sry for some reason both mine are missing all those emissions hoses heh so i don't know
maddzz1 Posted May 6, 2008 Posted May 6, 2008 The tube that comes off the back of the valve cover connects to a port on your intake right infront of your IAC. The one that comes off the front of the valve cover will have a couple vacuum lines: 2 are really short and connect to your intake right infront of the one above. THe other one will connect to the transducer for your egr valve. The second part of the harness clips to the 1st part (you will see how) and has one vacuum line that connects to the air box (or gets plugged if you buy the rustys air tube). Then it has 2 more lines that connect to vacuum solenoid right behind your ballist resistor on the driver side fender. When you get the pieces, LMK and I will take some pics if you need them to see how it all goes together. I just replaced all of them yesterday when I put my new valve cover gasket on.
Ben-88Comanche Posted May 17, 2008 Author Posted May 17, 2008 Hey yea i got all the parts, if you have a picture of how it all goes together can you post it? Thanks in advance
pingpong Posted May 18, 2008 Posted May 18, 2008 I made my own "warm wair intake" using a cheap ricer cone filter.. 6" of 2.5 aluminized exhaust tubing, and 1 brass air chuck.. worked great.. excpet for the blow by collecting in it :oops:
cromanyak Posted May 18, 2008 Posted May 18, 2008 Here's mine. I think I paid 20 for the filter on Ebay and 15 for chrome tube at Autozone. It comes with adaptors for your vacuum lines.
ComancheKid45 Posted May 18, 2008 Posted May 18, 2008 Mines basically the same as the 1 pictured above.....i purchased an Outerware fora Quad then and put it over my filter just to be safe in dusty conditions 8)
Ben-88Comanche Posted May 18, 2008 Author Posted May 18, 2008 AIght looks good thats about what my setup is, ill get a friend with a camera to come over tomarrow so i can show you the one line i don't know what to do with lol
Randy in Maine Posted May 19, 2008 Posted May 19, 2008 I have never found the factory air cleaner to be restrictive. So why do I need a cone?
Ben-88Comanche Posted May 19, 2008 Author Posted May 19, 2008 well the new cone filter sounds sick for starters and the throttle response is a lot better now that I have it on
comanche87 Posted May 19, 2008 Posted May 19, 2008 i made my own intake system. used a 3 inch piece of ehaust pipe and made holes for the lines that went into the air box. let me know ill take a pic and send it to you. it all cost me around 30 bucks.
A-man930 Posted May 19, 2008 Posted May 19, 2008 Does the rusty's tube have provisions for the small vacuum lines that come out the back of the airbox? The picture doesn't show... if it does then I'm probably going to jump on it
maddzz1 Posted May 19, 2008 Posted May 19, 2008 Does the rusty's tube have provisions for the small vacuum lines that come out the back of the airbox? The picture doesn't show... if it does then I'm probably going to jump on it It only has places for the two big lines to hook up. One of the small line on the back of the air box comes from the front of the air box so that one is gone when you remove the box. The other one you just plug up.
