comanche87 Posted April 30, 2008 Share Posted April 30, 2008 what does everyone thing of this kit. how much of a lift for the rear will it give. I'm looking at them for my mj but wanted to get everyones opinion of these. http://cgi.ebay.com/ebaymotors/ws/eBayI ... 49484&rd=1 Link to comment Share on other sites More sharing options...
Pete M Posted April 30, 2008 Share Posted April 30, 2008 I didn't see anything that said how long they were. Stock MJ shackles are already longer than stock XJ shackles so it's important to know how long these replacements are. Also, keep in mind that a shackle that is one inch longer than stock will only give 1/2" of lift. To get any reasonable lift, the shackle needs to be much longer than stock and that can cause problems like increased spring-wrap and also vibrations due to changing the angle of the U-joints in the driveshaft. Link to comment Share on other sites More sharing options...
mvusse Posted April 30, 2008 Share Posted April 30, 2008 According to the listed part number, they are 1" lift. But the ones pictured are not Daystar shackles. Either the picture is wrong, or the write-up is wrong. Link to comment Share on other sites More sharing options...
comanche87 Posted April 30, 2008 Author Share Posted April 30, 2008 i found this if this helps http://www.jackit.com/store/supercart.cgi?s=daykj60014 Link to comment Share on other sites More sharing options...
mvusse Posted April 30, 2008 Share Posted April 30, 2008 I had found this: http://www.jeeperz-creeperz.com/lift-shackles-rear-p-4001.html?manufacturers_id=2&osCsid=de3fe93edf2271ca325a90978a7583ea How come they look different? Link to comment Share on other sites More sharing options...
Pete M Posted April 30, 2008 Share Posted April 30, 2008 Well, off hand I can't remember what the exact lengths were for MJ and XJ shackles, but I'd wager that if it lifts the XJ 1" (meaning that it is 2" longer than a stock XJ shackle), you might see a half inch of lift on an MJ. Link to comment Share on other sites More sharing options...
comanche87 Posted April 30, 2008 Author Share Posted April 30, 2008 ok thanks pete. ill keep an eye on them. Link to comment Share on other sites More sharing options...
BLHTAZ Posted April 30, 2008 Share Posted April 30, 2008 As Pete mentioned...shackles are NOT a good thing to do. They have many more detrimental effects than positive. The better idea is to wait a little longer, save a little more money and do it the right way with some new springs. Even thought the ride quality sucks, I would rather see you put in some add-a-leafs rather than do shackles. If you are only looking for minimal lift and a temporary solution, the short AAL's will do it instead of using the long ones that will lift it 3" and be VERY stiff riding. ;) Link to comment Share on other sites More sharing options...
pingpong Posted April 30, 2008 Share Posted April 30, 2008 I have used Shackles to provide lift, and extra suspension travel. My favorite one to use is a Chevy drop shackle. That being said.. what a shackle lift does is move your pinion angle as pointed out, but it also moves the front edge of the tire closer to the wheel opening, Not really a good thing unless you have trimmed them, or plan on doing that Link to comment Share on other sites More sharing options...
comanche87 Posted April 30, 2008 Author Share Posted April 30, 2008 thanks guys. ill keep that in mind. i has fairly new leafs in it. they were replaced before the truck sat for 8 years. Link to comment Share on other sites More sharing options...
johngus Posted May 1, 2008 Share Posted May 1, 2008 These are the shackles I currently use: http://cgi.ebay.com/ebaymotors/84-02-Jeep-Cherokee-XJ-Rear-2-Lift-Shackle-Kit_W0QQcmdZViewItemQQcategoryZ42609QQihZ004QQitemZ140227886600QQrdZ1QQsspagenameZWDVW They give me about 1.25" extra in the lower holes. Here is an idea of what they look like: Link to comment Share on other sites More sharing options...
