excessive fogged windows
does anyone else have aproblem with there interior windows fogging up.
It rains a lot where I live. there is always an excessive amount of moisture on the inside of the windows and it takes a while for the defroster to do its job. I know I have a leak around my fuse box but I don't have a puddle on the floor just a little damp carpet. anyone have the same problem?
allen
Even a small amount of damp carpet will cause the issue you are describing. You need to check under the carpet as the MJ are known for leaking issues and there is likely more than you think. You will loose your floor pans before you know it if you don't keep an eye on it.
I don't know if I should of done this, but I don't have the brake booster or the clutch MC in my truck right now and its been raining alot here and I always got a puddle in the floor,, + the other day I washed out under the cowl and water came in on the passengers side.., so I just took a 3/16" drill bit and drilled about five holes in my floor.. It helped all the water drain, but like I said I don't know if those holes I drilled will help or hurt in the long run.. :dunno:
Go to the auto parts store and pick up the window cleaner that comes in a can. When you spray it , it foams up. Get the expensive one that says anti-fog. Then go to LOwes or Home Depot and they sell this stuff that that sucks the moisture outta your basement or crawlspace. Comes in a bucket, cost like five bucks and lasts 6-8 weeks.
I have a related problem. Don't fog up too much in the rain, however, in the morning my windshield has frost on it. ON THE INSIDE!
Actually, it frosts over on both inside and outside, but inside is always thicker.
