Air compressor.
chicofuentes0224
What you going to do with it?? Not good if your going paint alot, or run da sanders, but good nuff for impacts and air rachets..
Well, I was gonna do all that, so guess it's not a good idea. :cry:
well I miss read the auction.. 30 gal,, you can paint with that.. I though it said 5gal.. :nuts: you may get away with that compressor for spraying.. just match your paint gun to ut.. get you a air and water separator and put a filter on your gun,,
It fine for general shop use, however, you'll find it will come up short if you use sanders, orbital or otherwise, or tools that gobble a lot of air. My experience has been that you spend more time waiting for it to repressurize than you do on your project. No matter what tool I was using when you pulled the trigger it could'nt pump air fast enuf to maintain the status qoua. I had to work in timed segments. I finally had enuf o that & bought a dual cyl 80 gal comp. Now I'm as happy as a pig in s----. Gave the old noisy one to a kid down the street so he could sand & paint his bicycle.
