Carl'sMJ Posted March 14, 2008 Posted March 14, 2008 Does anybody do this? I was doing some reading this past week and came across this subject. I couldn't find any negatives... except that it mentioned converting the vertically positioned filter to a horizontal position... Not sure why, there looks to be plenty of room for the larger filter regardless, I'll take another look though. I currently have been using Fram filters (PH16)... according to the book the oversize Fram equivilant is a PH8A... Thoughts???
HOrnbrod Posted March 14, 2008 Posted March 14, 2008 Does anybody do this? I was doing some reading this past week and came across this subject. I couldn't find any negatives... except that it mentioned converting the vertically positioned filter to a horizontal position... Not sure why, there looks to be plenty of room for the larger filter regardless, I'll take another look though. I currently have been using Fram filters (PH16)... according to the book the oversize Fram equivilant is a PH8A... Thoughts??? I'm doing it on my 91 which has the horizontal filter, and am using a Mobil 1 M1-301 filter. More oil capacity is always good. :D The rear end of the canister comes close to the starter + cable, so when changing the filter I simply insulate it with a cloth or something, no problem. Other filters that can be used are: 5.178" HIGH, 3.660" DIAMETER 3/4-16 AC-Delco PF2 Motorcraft FL-1A Purolator PER1A Mobil 1 M1-301 6.93" HIGH, 3.660" DIAMETER 3/4-16 Napa 1773 Wix 51773 AC-Delco PF42 Motorcraft FL299 Purolator L40017
Randy in Maine Posted March 14, 2008 Posted March 14, 2008 I currently have been using Fram filters (PH16)... according to the book the oversize Fram equivilant is a PH8A... Thoughts??? You could do a lot better than Fram filters IMNSHO. http://www.knizefamily.net/minimopar/oi ... rence.html
Carl'sMJ Posted March 14, 2008 Author Posted March 14, 2008 What's wrong with Fram? Who makes a better product and why?
Carl'sMJ Posted March 14, 2008 Author Posted March 14, 2008 My bad... didn't see the link at first :oops:
jeepthing07 Posted March 14, 2008 Posted March 14, 2008 Wix 51515 is what i use (SAE thread for HO motors)
HOrnbrod Posted March 14, 2008 Posted March 14, 2008 I currently have been using Fram filters (PH16)... according to the book the oversize Fram equivilant is a PH8A... Thoughts??? You could do a lot better than Fram filters IMNSHO. http://www.knizefamily.net/minimopar/oi ... rence.html X2000 on the Frams. IMNSHO?? I know the last two are humble opinion. :D
Eagle Posted March 14, 2008 Posted March 14, 2008 ANYBODY makes a better filter than Fram. As to why you have to convert to the horizontal filter mount, it's because the vertical mount uses a metric thread, and the oversize filter(s) you want to use don't come in the metric thread. If you have a '92, you already have the horizontal mount so that won't be an issue for you. Personally, I can't think of a single good reason for making the conversion. If you use decent oil and a decent filter, and change the oil at a sane interval, the normal size filter is plenty adequate.
jtdesigns Posted March 14, 2008 Posted March 14, 2008 I always look for the filter with a anti-drain back valve. I just changed my oil and got a pretty blue Purolator Pureone advanced auto part# pl14619 for my mj.. It was the mid-grade filer..
Wildman Posted March 15, 2008 Posted March 15, 2008 I always look for the filter with a anti-drain back valve. I just changed my oil and got a pretty blue Purolator Pureone advanced auto part# pl14619for my mj.. It was the mid-grade filer.. Ditto, and even better is when Advance has the buy one get one free on the Purloators :D And I'm glad Randy in Maine posted that link, have not seen it in some time :thumbsup:
CWLONGSHOT Posted March 15, 2008 Posted March 15, 2008 Wix 51515 is what i use (SAE thread for HO motors) This is always my FIRST choice in oil filters. WIX makes GREAT oil filters!! FYI, NAPA filters are made by WIX CW
Eagle Posted March 15, 2008 Posted March 15, 2008 IMNSHO?? I know the last two are humble opinion. "In My Not So Humble Opinion"
jared Posted March 16, 2008 Posted March 16, 2008 i run factory mopar 090 filters. but i also work at the dealership 8) they fit almost every chrysler/dodge/jeep made
Eagle Posted March 16, 2008 Posted March 16, 2008 i run factory mopar 090 filters. but i also work at the dealership 8) they fit almost every chrysler/dodge/jeep made Except the '87 - '90 Jeep 4.0L with the metric threads. Never EVER use that filter on those.
ComancheKid45 Posted March 16, 2008 Posted March 16, 2008 i run factory mopar 090 filters. but i also work at the dealership 8) they fit almost every chrysler/dodge/jeep made Except the '87 - '90 Jeep 4.0L with the metric threads. Never EVER use that filter on those. Ive never tried a M090 on my 88....but excatly what would happen, you got me wondering now :nuts:
Eagle Posted March 16, 2008 Posted March 16, 2008 Yeah, it "falls" off -- under between 40 and 60 psi. Not exactly a cruise missile, but it makes quite a mess. I've had an oil filter gasket blow out, on a Toyota. Don't even want to think about the entire filter blowing off.
