sapoverde23 Posted 15 hours ago Posted 15 hours ago Original photo After 5 1/2 inch front lift and SOA swap with Dana 30 and Chrysler 8.25 rear After installing Dana 44 axles from a Jeep Wrangler JK This has been a two year project bringing this 88 MJ back to life. My issue is after swapping out the axles for Dana 44s from a JK the rear end sticks up to high. The rear was sitting a little high before the axle swap, but after swapping it is super noticeable. Everything I read said that a spring over axle conversion netted about 5 1/2 - 6 inches of lift. I figured I was safe with 5 1/2 worth of lift on the front. The photo doesn't do it justice, but the rear is closer to 8 inches now. I don't want to lift the front anymore because I want a lower center of gravity. Any suggestions on how I can remove some height in the rear would be greatly appreciated. Thanks in advance.
Pete M Posted 14 hours ago Posted 14 hours ago I would mix and match leafs with like an XJ or such with a flatter arch. supporting the main leaf is key here, so I'd probably start with the 3rd one down.
ThatJeepGuy Posted 14 hours ago Posted 14 hours ago Ditch your overload spring, it will flex better without it anyways. You could also swap out your mj shackles for stock xj shackles
Pete M Posted 12 hours ago Posted 12 hours ago he's going to need way more than that 3/4" another option is a 4" spring pack and going back to spring-under.
neohic Posted 21 minutes ago Posted 21 minutes ago Wagoneer springs are an option for a much lower SOA.
