sapoverde23
sapoverde23's Achievements
  1. Original photo After 5 1/2 inch front lift and SOA swap with Dana 30 and Chrysler 8.25 rear After installing Dana 44 axles from a Jeep Wrangler JK This has been a two year project bringing this 88 MJ back to life. My issue is after swapping out the axles for Dana 44s from a JK the rear end sticks up to high. The rear was sitting a little high before the axle swap, but after swapping it is super noticeable. Everything I read said that a spring over axle conversion netted about 5 1/2 - 6 inches of lift. I figured I was safe with 5 1/2 worth of lift on the front. The photo doesn't do it justice, but the rear is closer to 8 inches now. I don't want to lift the front anymore because I want a lower center of gravity. Any suggestions on how I can remove some height in the rear would be greatly appreciated. Thanks in advance.
