Pentti Posted July 26 Posted July 26 Does anyone have a clear photo of the ground that’s “above the hood release latch”. Also a photo of the recommended 10” jumper to another location.
AnotherOldJeepGuy Posted July 26 Posted July 26 I see why you are asking. I read your post and went out and looked, and to take the requested picture. No evidence of any ground at that described location I can find on my 4.0L 1990
jdog Posted July 26 Posted July 26 If I remember correctly, it's on drivers side behind the dash above the kick panel, I did it on my old one, I don't think I have any photos of it tho Would help to know the year of truck you are working on. Suspect renix era since it sounds like you are doing cruisers tips
Pentti Posted July 26 Author Posted July 26 I found it, you have to remove the lower dash panel to get to it. I cleaned the ground and for a minute I thought I had fixed my weird electrical gremlin; the AC making the radio turn off and also AC only functioning intermittently, but then it’s back at it again so now I don’t know what to do.
eaglescout526 Posted July 27 Posted July 27 1 hour ago, Pentti said: the AC making the radio turn off This is worrisome and makes me wonder what the condition is of the blower speed connector looks like. 1 hour ago, Pentti said: AC only functioning intermittently, Is the system full? This makes me think its cycling because it hits a point where theres low pressure and it cycles off until the pressure comes back. Also being said, did you do the blower motor ground mod?
AnotherOldJeepGuy Posted July 27 Posted July 27 16 hours ago, Pentti said: I found it, you have to remove the lower dash panel to get to it. I cleaned the ground and for a minute I thought I had fixed my weird electrical gremlin; the AC making the radio turn off and also AC only functioning intermittently, but then it’s back at it again so now I don’t know what to do. If you have the need to make it visible again, might go ahead and post that allusive pic for future reference.
AnotherOldJeepGuy Posted July 28 Posted July 28 I see one end at least in that posting. Not clear [to me at least] if that is the one Pentti was looking for, or the other end.
