89 MJ Posted June 12 Posted June 12 Does anyone have any recommendations for sway bar disconnect brands? I have absolutely zero interest in something like an anti rock sway bar, I’m just after a set of quick disconnects. They MUST be quiet going down the road. I had a set on my MJ that rattled a ton. I don’t want that again. This is for the Wrangler, but I trust y’all more than Wrangler folks.
89 MJ Posted June 12 Author Posted June 12 1 minute ago, fiatslug87 said: I have the JKS disconnects on my 88 MJ, seem OK. Good to know. That was the first result on the Google machine and the one I’ve heard of the most. Thank you.
Htchevyii Posted June 12 Posted June 12 I've got Zone ones. They've been on there for 3 or 4 years without any issues.
89 MJ Posted June 12 Author Posted June 12 10 hours ago, Htchevyii said: I've got Zone ones. They've been on there for 3 or 4 years without any issues. Thank you. I’m glad to hear they’ve had zero issues, especially with how your truck is used.
coheed Posted June 12 Posted June 12 I also have some JKS ones on my truck and have had no issues with them. Just make sure to grease them often, mine seem to push out the grease more than I would expect.
89 MJ Posted June 12 Author Posted June 12 7 minutes ago, coheed said: I also have some JKS ones on my truck and have had no issues with them. Just make sure to grease them often, mine seem to push out the grease more than I would expect. Thanks for the tip, if that’s the route I go, I’ll be sure to do that.
Kedosp Posted June 13 Posted June 13 I’ve had JKS disconnects for about a year and they’ve been great. I greased then when I installed and haven’t had to re lube them yet. No rattles at all
derf Posted June 13 Posted June 13 I've had JKS on several Jeeps. Happy with all of them. I would shoot some grease in them when greasing steering joints every oil change. That seemed to be enough.
89 MJ Posted June 13 Author Posted June 13 8 minutes ago, Kedosp said: I’ve had JKS disconnects for about a year and they’ve been great. I greased then when I installed and haven’t had to re lube them yet. No rattles at all Perfect! I’m perfectly happy greasing something once in a while, but I’m especially glad to hear you haven’t had to grease them again yet.
