Drahcir495 Posted May 24 Posted May 24 Question - can you put a transfercase on a two wheel drive ax15 manual transmission? Or do you need an output that can mate up to a 2wd?
derf Posted May 24 Posted May 24 You need a different output shaft in the transmission and an adapter that you can bolt the transfer case to. Both can be found with a little bit of searching.
Drahcir495 Posted May 24 Author Posted May 24 Thank you. That’s what I was not wanting to hear but I figured that. This is making my decision harder. I am looking at a 2 door XJ with a manual transmission or a 2wd Comanche with everything to make it manual 4x4.
JZLAJeep Posted May 24 Posted May 24 27 minutes ago, Drahcir495 said: Thank you. That’s what I was not wanting to hear but I figured that. This is making my decision harder. I am looking at a 2 door XJ with a manual transmission or a 2wd Comanche with everything to make it manual 4x4. Get them both!
Pete M Posted May 24 Posted May 24 do pay attention to your radar as you go. we're getting some intense storms here and there.
Drahcir495 Posted June 1 Author Posted June 1 The owner of the Cherokee says he may be keeping it. I may have to buy the MJ or get a motorcycle - choices 😬
