OSCDumpTruck Posted 2 hours ago Author Share Posted 2 hours ago Thank you very much! Have wanted to make a build thread for a long time now. I really do like the 2.5, it’s a great motor for running around town. Not having new flywheels available is a bummer. Couple other things I just thought of that I plan on doing. 1: I have a full rebuild ready for the throttle body (injector, regulator, seals, etc) 2: Someday swap in my non-disconnect front axle that’s been sitting in my shed. I converted my stock disconnect one to a solid axle shaft in 2021. The first seal lasted a couple months. The second one is still going strong! 3. Harmonic balancer. Link to comment Share on other sites More sharing options...
eaglescout526 Posted 1 hour ago Share Posted 1 hour ago 53 minutes ago, OSCDumpTruck said: Not having new flywheels available is a bummer. Nahhh we don’t need new ones. A light sanding with 1000grit does the trick for surfacing Link to comment Share on other sites More sharing options...
OSCDumpTruck Posted 1 hour ago Author Share Posted 1 hour ago 26 minutes ago, eaglescout526 said: Nahhh we don’t need new ones. A light sanding with 1000grit does the trick for surfacing I was pretty bummed about it a week ago! We’ll keep them on the road one way or another. My plan was to clean up my flywheel and use a clutch for a 94 2.5 XJ with my TBI flywheel. From what I’ve gathered researching, that should work. On the ZJs, they had the external slave in 93. No conversion needed when I did that swap on my 98, just a CPS for a 98 ax15 XJ. Link to comment Share on other sites More sharing options...
eaglescout526 Posted 38 minutes ago Share Posted 38 minutes ago If youre wanting to do a external slave conversion, find a 84-86 with a manual set up and youll be able to use that set up on the 87-90 bell houses just fine. I did such on my 88 MJ just fine and man do I love that swap! I thing on this will be finding the ball pivot for the clutch fork and I was able to use later year chrysler ball pivot on my 84 when I swapped to the TBI bell house also with no issues. Link to comment Share on other sites More sharing options...
