OSCDumpTruck Posted 1 hour ago Author Share Posted 1 hour ago Thank you very much! Have wanted to make a build thread for a long time now. I really do like the 2.5, it’s a great motor for running around town. Not having new flywheels available is a bummer. Couple other things I just thought of that I plan on doing. 1: I have a full rebuild ready for the throttle body (injector, regulator, seals, etc) 2: Someday swap in my non-disconnect front axle that’s been sitting in my shed. I converted my stock disconnect one to a solid axle shaft in 2021. The first seal lasted a couple months. The second one is still going strong! 3. Harmonic balancer. Link to comment Share on other sites More sharing options...
eaglescout526 Posted 41 minutes ago Share Posted 41 minutes ago 53 minutes ago, OSCDumpTruck said: Not having new flywheels available is a bummer. Nahhh we don’t need new ones. A light sanding with 1000grit does the trick for surfacing Link to comment Share on other sites More sharing options...
OSCDumpTruck Posted 9 minutes ago Author Share Posted 9 minutes ago 26 minutes ago, eaglescout526 said: Nahhh we don’t need new ones. A light sanding with 1000grit does the trick for surfacing I was pretty bummed about it a week ago! We’ll keep them on the road one way or another. My plan was to clean up my flywheel and use a clutch for a 94 2.5 XJ with my TBI flywheel. From what I’ve gathered researching, that should work. On the ZJs, they had the external slave in 93. No conversion needed when I did that swap on my 98, just a CPS for a 98 ax15 XJ. Link to comment Share on other sites More sharing options...
