COMANCH3 Posted May 22 Posted May 22 Time to replace the current tires on the MJ and wanted to know if I’d see a significant loss in power or potential axel/driveshaft issues. Current tires are Toyo Eclipse P205/70 R15 with stock steel 15x6 wheels. Wheel and tire weight 40 lbs. I have a stock set of alloy 15x7s that weigh 22 lbs each. I am considering the same size tires or 215/70 R15 on the alloy wheels. Depending on if I go all season or all terrain, and the size of the tire, estimated weight range is between 44 and 50 lbs. Any issues moving up to the bigger wheel, tire, and additional rotating mass? I know it’s very minor, one size up on both the wheel and tire, but once they’re purchased and on the truck, I’m stuck with them. Do you recommend staying at 40 or will I be fine at 45-50 lbs.? I have the very desired 2.5L, 2WD, 4-speed manual with no power steering! Current setup is “peppy” for being the 2.5L. I drive the MJ about a dozen times a year. Given my location, you must use the interstates (65 mph) to get from point A to B. Thanks in advance.
JZLAJeep Posted May 22 Posted May 22 Those are pretty small tires. We usually run 235/75/15 on MJ and XJ. I can't imagine you'll see any difference with 215/70/15 over 205/70/15. You can likely go larger without real noticeable difference in performance. Given how little you drive it, I'd look for used tires. Can find used tires for 1/3 the price of new. I've gone to buying used tires for all of my vehicles... When shopping for used, it's likely easier to find 235/75/15 used than 215/70/15 or 205/70/15, but keep your eye out for any 4 matching 15" tires...
garyweb3 Posted May 22 Posted May 22 (edited) I run 215/70/R15 Radial TA's on my 87 Comanche with the same driveline as your truck. They're on the factory alloy wheels. Been on the truck for over 30 years. Not the same tires the whole time. Edited May 23 by garyweb3 wrong info
COMANCH3 Posted May 23 Author Posted May 23 I’m assuming anything in the 195-225 range will be fine, given that’s what they came with. Wasn’t sure if the weight from a heavier tire in that size range would affect anything, specifically acceleration with the smaller engine. My neighbor has a CJ8 with a 2.5L and the tire shop talked him into putting on the biggest KO2s (31s or 32s) that would fit. A month later they were sitting in his driveway for sale. He said he regretted going that big and lost all power.
dasbulliwagen Posted May 28 Posted May 28 Another 2.5 guy here. You most likely won't notice anything with the weight difference or size difference on anything up to a 235. I too started out with 205's then on to 235's, then on to JK takeoffs measured at close to 32". I didn't notice any difference up to the 235's. I think you'll be fine with what you're planning on. To add to that, on the smaller sizes I had the 3.55 axle in it, and when I converted to 4wd I went to 4.10's with the JK wheels and tires, which helped but 5th gear is almost unusable with the 2.5's power.
Porquer Posted May 28 Posted May 28 I’m running 30” tires with 3.55 gears. Runs around flat ground just fine, struggles a little on the hills, but not unbearable for me. However, I don’t have overdrive.
mjeff87 Posted May 29 Posted May 29 I ran 235/75/15's (on steel wagon wheels to boot) on mine when it was still a 2WD-2.5L, although mine had a 5 speed and 4.10's. It ran fine. Couldn't tell any difference between them and the stock 205's.
