mjfreak Posted yesterday at 01:09 AM Share Posted yesterday at 01:09 AM I searched and didn't see anything like what I've got going on....my blinkers work perfectly....and then nothing....I've pulled fuse block apart and cleaned it....added all the suggested grounds, updated front bulb sockets to 97+, rear is a flatbed with led lights.Β When they stop working, I wiggle all the wires under dash with no change......then just randomly they work again....when they aren't working i have found that the purple wire on the multi function swith will be blinking with test light but blinkers aren't working....if i had hair I would be pulling it out.Β Open to suggestionsΒ Link to comment Share on other sites More sharing options...
Pete M Posted yesterday at 02:13 AM Share Posted yesterday at 02:13 AM could be a loose or corroded connection in the wiring or in the multi-function stalk.Β those suck to have to track down. Β Β did this happen before the LEDs were installed? Β Link to comment Share on other sites More sharing options...
mjfreak Posted yesterday at 03:20 AM Author Share Posted yesterday at 03:20 AM Before and after....nothing I have done caused or helped situationΒ Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted yesterday at 04:24 AM Share Posted yesterday at 04:24 AM The most common issue with the blinkers is the front bulb sockets themselves. They get corroded and cause all sorts of strange issues. The only fix is to cut the old ones off and wire new ones in. Link to comment Share on other sites More sharing options...
mjfreak Posted yesterday at 02:43 PM Author Share Posted yesterday at 02:43 PM 10 hours ago, Eagle_SX4 said: The most common issue with the blinkers is the front bulb sockets themselves. They get corroded and cause all sorts of strange issues. The only fix is to cut the old ones off and wire new ones in. Been done when I upgraded to 97+ front clip..... Link to comment Share on other sites More sharing options...
mjfreak Posted 20 hours ago Author Share Posted 20 hours ago Something else I noticed today. When blinkers are in FU mode.....and if hit brakes...both blinker indicators on dash light up solid...... Link to comment Share on other sites More sharing options...
Pete M Posted 19 hours ago Share Posted 19 hours ago ground loss somewhere?Β Link to comment Share on other sites More sharing options...
watchamakalit Posted 18 hours ago Share Posted 18 hours ago Check your hazard switch in the column. I know mine can occasionally get bumped to the point its almost half engaged and causes my signals to do goofy stuff. I just pull it or push it (I don't remember which way is off ) and all is right again Link to comment Share on other sites More sharing options...
mjfreak Posted 2 hours ago Author Share Posted 2 hours ago 17 hours ago, Pete M said: ground loss somewhere?Β Thats what I'm leaning towards but not sure where to start.....guess with front blinker socket as they were used....not sure if the 97+ were known to have issues but I've watched a few videos whith identical problem and front blinker sockets fixed it.... Link to comment Share on other sites More sharing options...
Pete M Posted 1 hour ago Share Posted 1 hour ago make sure the little tab in the bottom of the socket isn't squashed flat and failing to make contact. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 56 minutes ago Share Posted 56 minutes ago Have you tried swapping the turn signal and hazard flashers yet? Link to comment Share on other sites More sharing options...
