Dandxj Posted 8 hours ago Share Posted 8 hours ago Did the MJ ever come with an automatic, bench seats and a floor console? If not has anyone tried to create this combination? Link to comment Share on other sites More sharing options...
89 MJ Posted 7 hours ago Share Posted 7 hours ago Which floor console are you after? Micro, mini, or full? Link to comment Share on other sites More sharing options...
Dandxj Posted 7 hours ago Author Share Posted 7 hours ago I must of had a brain fart. I meant to post this in the repair/ mod section. Anyway, I want to put an AW4 in with a bench seat. The MJ currently has a AX5 manual. I know the full console will not fit. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 4 hours ago Share Posted 4 hours ago Is this what you are after. https://www.ebay.com/itm/256492974100 It is the only one I have ever seen or can find pics of. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 4 hours ago Share Posted 4 hours ago Found some other pics of a mini automatic console. This one was in an XJ. This one is in a Comanche. Link to comment Share on other sites More sharing options...
Dandxj Posted 3 hours ago Author Share Posted 3 hours ago Thanks Eagle_SX4. I believe that is what I am looking for. I did not know they came in an XJ. I always thought they all had full consoles. That one on Ebay is kinda pricey. I have 2WD so I would still need a cover for the TC lever hole. Link to comment Share on other sites More sharing options...
fiatslug87 Posted 3 hours ago Share Posted 3 hours ago Does your manual have the mini console? If it does all you need is the auto insert, it just takes place of the boot. I think the mini console auto version is slightly longer at the front but the shorter one may work. Edit: I have a tan one I can dig out if you need it, but I don’t think I have the auto insert. Link to comment Share on other sites More sharing options...
Dandxj Posted 3 hours ago Author Share Posted 3 hours ago Yes I have the manual mini console. The boot opening ends about 3 inches below the top. It looks to end about between the Park (P) and Reverse (R) on the Ebay picture sent by Eagle-SX4. I am not sure of any width differences. I wonder how bad it would look to cut off the E brake and storage box from a XJ console. When you say "auto insert" do you mean the cover with PRND on it that the shifter sticks through? I wonder if one from a full size XJ would fit. Link to comment Share on other sites More sharing options...
fiatslug87 Posted 2 hours ago Share Posted 2 hours ago Yes that’s what I meant, that whole piece should just snap right in replacing the boot. Link to comment Share on other sites More sharing options...
