Dandxj Posted 5 hours ago Share Posted 5 hours ago Did the MJ ever come with an automatic, bench seats and a floor console? If not has anyone tried to create this combination? Link to comment Share on other sites More sharing options...
89 MJ Posted 4 hours ago Share Posted 4 hours ago Which floor console are you after? Micro, mini, or full? Link to comment Share on other sites More sharing options...
Dandxj Posted 3 hours ago Author Share Posted 3 hours ago I must of had a brain fart. I meant to post this in the repair/ mod section. Anyway, I want to put an AW4 in with a bench seat. The MJ currently has a AX5 manual. I know the full console will not fit. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 1 hour ago Share Posted 1 hour ago Is this what you are after. https://www.ebay.com/itm/256492974100 It is the only one I have ever seen or can find pics of. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 1 hour ago Share Posted 1 hour ago Found some other pics of a mini automatic console. This one was in an XJ. This one is in a Comanche. Link to comment Share on other sites More sharing options...
Dandxj Posted 47 minutes ago Author Share Posted 47 minutes ago Thanks Eagle_SX4. I believe that is what I am looking for. I did not know they came in an XJ. I always thought they all had full consoles. That one on Ebay is kinda pricey. I have 2WD so I would still need a cover for the TC lever hole. Link to comment Share on other sites More sharing options...
fiatslug87 Posted 37 minutes ago Share Posted 37 minutes ago Does your manual have the mini console? If it does all you need is the auto insert, it just takes place of the boot. I think the mini console auto version is slightly longer at the front but the shorter one may work. Edit: I have a tan one I can dig out if you need it, but I don’t think I have the auto insert. Link to comment Share on other sites More sharing options...
Dandxj Posted just now Author Share Posted just now Yes I have the manual mini console. The boot opening ends about 3 inches below the top. It looks to end about between the Park (P) and Reverse (R) on the Ebay picture sent by Eagle-SX4. I am not sure of any width differences. I wonder how bad it would look to cut off the E brake and storage box from a XJ console. When you say "auto insert" do you mean the cover with PRND on it that the shifter sticks through? I wonder if one from a full size XJ would fit. Link to comment Share on other sites More sharing options...
